Author Topic: Wish me luck, though it may take a looooong time!!  (Read 4841 times)
Re: Wish me luck, though it may take a looooong time!!
« Reply #15 on: 07 July 2008, 20:23:14 »
Right then Danny...
This has gone on long enough! If it was me in your position I'd have driven it through their window by now.
Can you confirm the following mate because I can't be 100% based on the above:
*Where is the coolant feed for the vaporisor coming from, and where is it returning to?
I can't promise miracles but I would love to see this install.
If it's having problems driving any distance, I'll come to you, for the cost of fuel (LPG :D ) only, purely because I don't like being beaten by this kind of thing. We could arrange it so that if needs be, I can be in telephone contact with Kev in case we need an extra brain or confirmation on anything.
In order for this to be effective, we need the cable and the software. I think you should Demand this from the original installer even if it's only on a loan basis. It's the least they can do given the heartache you've had with this, if they can't sort out the problems they shouldn't take issue with a second pair of eyes looking it over...
Danny
  • Wigan, Greater Manchester
« Reply #16 on: 07 July 2008, 20:42:20 »
Right then Danny...
the coolant feed goes from the coolant tank to the vapouriser, then from the vapouriser to the engine on the right side looking from the front (cant move wires far enough away to see exactly where) then it returns through the radiator by the look of it
this is the thing though which i suspect you were aiming at(?), how long should it take for the vapouriser to get hot enough that i cant keep my finger on it?
felt the pipes that run from the coolant tank, they felt nice and toastie after a minute or so, as did the one coming away from the vaporiser to the engine block, also toastie, the evaporator.... cold
« Reply #17 on: 07 July 2008, 20:45:42 »
Right then Danny...
WHEN CAN I COME AND LOOK AT IT  >:(
 ;)  ;D
Danny
« Reply #18 on: 07 July 2008, 20:52:13 »
are you free thursday?? do you have any access to an ecu lead?
i'm still going to go to citizens advice tomorrow and ask their opinion, do you recommend i ask the garage for a part refund in return for me never going back there again?
« Last Edit: 07 July 2008, 20:52:46 by D4NNY »
« Reply #19 on: 07 July 2008, 20:54:28 »
Alas not Thursday, how about the weekend?
I only have the lead for my stag kit, suspect yours will be much different... :(
Martin_1962
« Reply #20 on: 07 July 2008, 20:58:40 »
Want to borrow my ROmano lead - there are only a few designs and most use AEB
That hot water feed is too cold - you need to plumb into the heater pipes, my evaporator is bloddy hot!
« Reply #21 on: 07 July 2008, 21:00:10 »
Yes please to the lead - I could collect it en route and call in for a cuppa - and show you my install.
Danny's will also be hot once I see what's going on with it!
« Reply #22 on: 07 July 2008, 21:00:52 »
Just to add - you could cook an egg on mine!
Danny
« Reply #23 on: 07 July 2008, 21:02:16 »
saturday after dinner time, not sure exactly when i'll be home from work but technically half 12 onwards??
this is the connector:
mine used to be hot, hence it used to run sweet!!!
« Last Edit: 07 July 2008, 21:03:16 by D4NNY »
« Reply #24 on: 07 July 2008, 21:05:04 »
PM sent. Hopefully we can do some replumbing and it'll be a god'un...
Martin_1962
« Reply #25 on: 07 July 2008, 21:09:51 »
WHich day ?
May be CBSing
Martin_1962
« Reply #26 on: 07 July 2008, 21:10:24 »
Looks like the same as my ROmano lead
« Reply #27 on: 07 July 2008, 21:10:35 »
WHich day ?
May be CBSing
we're looking at Saturday - it would be AM passing worcs..
Martin_1962
« Reply #28 on: 07 July 2008, 21:26:53 »
WHich day ?
May be CBSing
May have to be silly early!
« Reply #29 on: 07 July 2008, 21:27:28 »
That may work fine :D
Pages: 1 [2] 3 4  All   Go Up
