Author Topic: rear sunblind  (Read 7288 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
rear sunblind
« on: 10 July 2015, 11:06:02 »
Works then it doesn't and so on and so on... Can hear it clicking when pressing the button..  Amy thought's peeps?
Re: rear sunblind
« Reply #1 on: 10 July 2015, 11:23:24 »
Owning an 'ever so 'umble' MV6 I don't have the luxury of a rear blind. :'( :'( :'(
vauxsull
    • 3.0 Elite
Re: rear sunblind
« Reply #2 on: 10 July 2015, 11:34:38 »
Neither do I at the moment 😊
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: rear sunblind
« Reply #3 on: 10 July 2015, 11:40:44 »
There more trouble than there worth in my honest option, the motors jam, the elbow levers jam or bend, the switch cover will decide at any point to pop off and launch its contents of parts inside the car, there a pita to remove and or repair, if its closed I would just leave it be and pretend its not there.
pauls
  • By the sea minehead
    • Bmw x3
Re: rear sunblind
« Reply #4 on: 10 July 2015, 11:41:30 »
If you get somebody to press the button while you try and prise the blind up, if this works spray some silicon on the running gear.
I fitted one to my other elite i had and i found that it stuck now and again so i went into the boot and undid the shelf holding screws this allowed the blind to move around better. The edge of the blind gets stuck against the side of the shelf itself.(cardboard rubbish)
vauxsull
    • 3.0 Elite
Re: rear sunblind
« Reply #5 on: 10 July 2015, 11:48:32 »
I seeee I shall try this then.. Cheers for the info peeps.
Diamond Black Geezer
    • & a silly coupe coming...
Re: rear sunblind
« Reply #6 on: 10 July 2015, 12:01:37 »
Personally love mine.
Cant say I've ever had any trouble, other than being a little sticky when I bought the car, but some silicone stray sorted that out.
As above, check with someone working on the other end, also I'd say try the switch, eliminate that, then move onto the blind itself.
I have a sneaking suspicion that the bootlid button works very well as a temporary replacement. (of course you have to ping the rubberised front off, but once you've done that the switches are basically the same as the PFLs)
Re: rear sunblind
« Reply #7 on: 10 July 2015, 13:13:04 »
2002 Elite here, so no blind  :(
But I do have rear tints  8)
They can be a right PITA though when they stop working.  :(
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: rear sunblind
« Reply #8 on: 10 July 2015, 16:10:48 »
Spot On  :y  Done two now and after few months click click  :'(  If you wanna have a quick go at getting it back to life....... While pressing the button,get someone to hit the shelf underside from within the boot. that worked for me  :y :y for a while  ;D ;D
vauxsull
    • 3.0 Elite
Re: rear sunblind
« Reply #9 on: 10 July 2015, 16:20:02 »
I shall try all of these ideas.. Nothing to lose have I ?
zirk
  • Epping Forest
Re: rear sunblind
« Reply #10 on: 10 July 2015, 18:06:28 »
Apart from it jamming while its up, then its a strip down job.
vauxsull
    • 3.0 Elite
Re: rear sunblind
« Reply #11 on: 10 July 2015, 20:08:54 »
This sounds complicated 😱
4x4
Re: rear sunblind
« Reply #12 on: 10 July 2015, 20:11:00 »
Have you tried contacting a company that makes blinds,they do a good selection of different designs and colours  :y
vauxsull
    • 3.0 Elite
Re: rear sunblind
« Reply #13 on: 10 July 2015, 20:12:54 »
You meen like a set of " chintzy" blinds 😁
4x4
Re: rear sunblind
« Reply #14 on: 10 July 2015, 20:14:14 »
What ever floats your boat  ;D
