Got Sky? Want Discounted Movies/Sports?
Started by tunnie, 13 July 2015, 09:01:10
Sounds like an app is hogging data, install this on your PC:
http://www.charlesproxy.com
Make your PC work as a proxy, configure it on the phone. (Set your PC IP as the proxy in the Wifi)
You should see all traffic your phone does, see what the culprit is  :y
Quote from: tunnie on 18 July 2015, 22:27:16
In English now? ::) ;D
My point is that it is still doing exactly the same but passing it through the signal booster first. Plus, more importantly, this started suddenly just after a line fault was rectified with no changes to the phone whatsoever. Those 2 points are really confusing me!
Humm. Need to find out what is taking the bandwidth  :-\
Quote from: tunnie on 18 July 2015, 22:44:36
I agree... But I still don't understand why the problem doesn't manifest itself when using mobile data at home which is through my calls over wifi signal booster :-\ I have unlimited data so my phone is set to sync everything over mobile and wifi
Also, it only happens on my wifi, not anywhere else :-\
