Author Topic: Front brake pads question  (Read 3327 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 15 July 2015, 17:17:23 »
Just opened a box of new VX front brake pads and two of them are different from the other two. See link.
https://www.flickr.com/photos/53447058@N05/19100126023/in/datetaken/
Is this normal?
If it is normal. Which ones get fitted on the inside and which ones get fitted on the outside of the disc?
Thanks
Re: Front brake pads question
« Reply #1 on: 15 July 2015, 18:00:20 »
Is normal... The studded ones only fit one way, but damnediff I can remember which as I have different calipers on mine :-[
« Reply #2 on: 15 July 2015, 18:16:38 »
Normal, I think I put the padded ones on the inside, otherwise the caliper would push against it.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 15 July 2015, 18:26:20 »
Pad with shim goes on outside.
Hoof'land storeman.
EMD
  • Noofhampton
    • 95t
« Reply #4 on: 15 July 2015, 19:38:27 »
Which way is it  :-\
Omegatitis
« Reply #5 on: 15 July 2015, 20:05:39 »
Looking at picture, yeah that's how I do mine thinking about it.
« Reply #6 on: 15 July 2015, 20:56:43 »
Agreed, helps prevent squealing :y
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #7 on: 15 July 2015, 22:22:29 »
Take the shims of the old pads and fit them to the non shimed new pads. They're only heald on with double sided tape.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #8 on: 16 July 2015, 01:39:31 »
trw pads have shims on both, no squealing
EMD
  • Noofhampton
    • 95t
« Reply #9 on: 16 July 2015, 18:08:39 »
So the one in the guide is wrong way  ???
Omegatitis
« Reply #10 on: 16 July 2015, 20:03:00 »
Not necessarily ;)
Might simply be a different brand of pad without the shims fitted... :y
biggriffin
« Reply #11 on: 16 July 2015, 20:10:10 »
Yup!
That guide needs editing now, whoops :P
Hoof'land storeman.
Andy A
  • Bristol UK
« Reply #12 on: 17 July 2015, 08:58:12 »
I will fit the pad with the shim on the out side.  :y
On the rear pads do I put copper slip between the shim and the pad or just between the shim and the caliper?
« Reply #13 on: 17 July 2015, 16:12:00 »
Both or neither, and don't forget the top and bottom edges of the backing plates :y
Andy A
  • Bristol UK
« Reply #14 on: 18 July 2015, 08:38:24 »
Thanks all for your help and advice.  :y
