Author Topic: Brake master cylinder  (Read 16658 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 19 July 2015, 11:59:35 »
Has anyone removed and overhauled the master cylinder on a 3.2? It looks fairly straightforward in Haynes for the 3.0. If so any issues and are seal kits available for them? :y
Re: Brake master cylinder
« Reply #1 on: 19 July 2015, 13:02:46 »
Normally pretty bulletproof... Has yours gone?
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #2 on: 19 July 2015, 13:58:39 »
Yep fairly easy to remove, but if needing to remove the brake pedal, and I think you do(?) then acquire a good replacement brake light switch first, as the tangs almost always break off on removal. Very very Brital
Shackeng
  • Ramsbury
« Reply #3 on: 19 July 2015, 15:32:01 »
Not gone Paul, but the Elite pedal has always been a bit soft compared to the TD, despite fluid change, brake bleeding etc. So i thought I would replace all the seals in the system, hoping for an improvement. :y
Shackeng
  • Ramsbury
« Reply #4 on: 19 July 2015, 15:32:46 »
Thanks Chris, are the seals readily avlbl. do you know? :y
chrisgixer
  • Woking ham
  • Banned
« Reply #5 on: 19 July 2015, 17:25:13 »
Sorry should of said, I have removed one. I have not opened one up in any way.
chrisgixer
  • Woking ham
  • Banned
« Reply #6 on: 19 July 2015, 17:25:56 »
Could that be servo/vacuum related?
Shackeng
  • Ramsbury
« Reply #7 on: 19 July 2015, 17:35:01 »
Hmm, how can I test for that?
chrisgixer
  • Woking ham
  • Banned
« Reply #8 on: 19 July 2015, 17:40:55 »
First question might be, is there a leak in the vac pipe? Especially where the clip holds the vac pipe away from the air con pipe by the scuttle drain.
They are known to wear through if the clip brakes or hoes missing as the two rub together.
Shackeng
  • Ramsbury
« Reply #9 on: 19 July 2015, 19:56:53 »
I'll have a look, but as it's vac. it may be difficult to spot, unless a clip is missing :-\
chrisgixer
  • Woking ham
  • Banned
« Reply #10 on: 19 July 2015, 19:58:18 »
Ideally needs removal and examining, but it will likely hiss with engine running.
Shackeng
  • Ramsbury
« Reply #11 on: 19 July 2015, 19:59:11 »
The master cylinder or vac pipe? :-\
chrisgixer
  • Woking ham
  • Banned
« Reply #12 on: 19 July 2015, 20:00:04 »
The master cylinder? :-\
No, vac pipe.
Does the pedal sink at stand still on tickover?
Shackeng
  • Ramsbury
« Reply #13 on: 19 July 2015, 20:02:41 »
Can't remember, I think yes, but will check. Is this a good or bad sign?
chrisgixer
  • Woking ham
  • Banned
« Reply #14 on: 19 July 2015, 20:18:19 »
Might be a vac leak in the plenum to servo pipe. Might be servo diaphram (?thingy) leaking inside the servo itself.
But servo pipe is quite common to chaif through and leak. :)
Pages: [1] 2 3 4  All   Go Up
