Author Topic: Intermittent Speedo  (Read 5921 times)
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Intermittent Speedo
« on: 25 July 2015, 09:28:18 »
My speedo has decided to only work part time, choosing the most inopportune moments to stop working.
I`m thinking it will be the signal sender unit or wiring at fault, is the sender unit on the gearbox or is it related to the ABS/traction control system?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Intermittent Speedo
« Reply #1 on: 25 July 2015, 09:33:32 »
Yep, all of them, well ABS actually, normally a good bash with your fist on top of the dash works, if not take the clock housing out and refit it making sure the push fit connections are seat properly before you start ripping your engine bay apart.  ;)
« Last Edit: 25 July 2015, 09:36:01 by zirk »
Mr Gav
  • Leeds
« Reply #2 on: 25 July 2015, 16:10:46 »
Cheers Zirk, I`ll try that next time, it`s been behaving itself since this mornings trip past eight speed cameras.
« Reply #3 on: 26 July 2015, 11:07:00 »
Do MID functions relying on speed (eg, consumption) go haywire at same time?
Mr Gav
  • Leeds
« Reply #4 on: 27 July 2015, 16:48:31 »
No, it`s only the speedo TB, it`ll stop working and then just start working again, there doesn`t seem to be any time or anything in particular, it`s just random.
It`s done it about three times in the last week now.
« Reply #5 on: 27 July 2015, 18:00:23 »
New aka second hand speedo required then... Which reminds me :-[
« Reply #6 on: 27 July 2015, 18:11:56 »
Blimey, do inferior FL clocks hit about 12yrs, then fail ;D
Mr Gav
  • Leeds
« Reply #7 on: 27 July 2015, 18:38:01 »
Nah, more like 15 years  ;)
Mr Gav
  • Leeds
« Reply #8 on: 04 August 2015, 09:47:00 »
Right a bit more info on this, it happened again on the way to Manchester airport on Friday twice, both times it happened it started working again within a couple of minutes.
When it stops working the speedo needle drops back to zero about 1-2 seconds later TC and ABS lights come on and all the speed related functions on the MID aren`t working then when it starts working again the speedo needle springs back into action, 1-2 seconds later the TC and ABS lights come on and then all the MID speed related functions are working again.
It seems to me that it`s not a dash problem unless the MID gets its speed signal from the dash, but whatever generates the speed signal.
zirk
  • Epping Forest
« Reply #9 on: 04 August 2015, 14:20:38 »
With TC and ABS light coming on does sound like the ABS ECU (and or Pump) as the ECU unit is easier to change than the whole unit I would start with that, you could try unplugging the connector and re connect as few times and checking its clean from grease, oil etc but to be honest getting access to it is a bit of a pain, so while your there change the ECU.
« Reply #10 on: 04 August 2015, 14:37:27 »
Classic ABS fault on post 1998 V6's.  It will get progressively worse IME
Mr Gav
  • Leeds
« Reply #11 on: 04 August 2015, 16:31:16 »
Looks like a new ABS ECU is required then, cheers guys  :y
