Author Topic: O2 sensor?  (Read 2778 times)
valliant1972
  • UK
    • omega 2.5 v6 cdx
O2 sensor?
« on: 26 July 2015, 23:37:21 »
Hi run the "My Naff Code Reader" on my V6 and was wondering about the block reading for the 02 sensor.  The engine had only done a short trip before plugging in.
readout for the "My Naff Code Reader"
"My Naff Code Reader" 100219a - PC based diagnostic tool
Date and time>,24/07/2015. 19:3223
Workshop information:
hkj
Selected model>,2000 (Y),Omega-B,Engine,X 25 XE
Control Unit:
KW82 protocol initialized.
ECU ID= HH,90492382,0261203588,1037350104,03,
Measuring blocks information:
Identifier,0D
Battery Voltage,14.2 V
Immobiliser Signal,Received
Immobiliser,Active
TPS Signal (Throttle Position Sensor),0.51 V
Simulated Idle Position,Active
Simulated Full Load Switch,Inactive
Mass Air Flow Sensor,1.16 V
Mass Air Flow Sensor,32 kg/h
Coolant Temperature,2.83 V
Coolant Temperature,37 °C
Intake Air Temperature,3.47 V
Intake Air Temperature,22 °C
Engine Type,6 Cylinder
Transmission Coding,Automatic Transmission
Park/Neutral Switch,P - N  0V
A/C Information Switch (Air Conditioning),Inactive 0V
A/C Compressor Switch (Air Conditioning),Inactive 0V
Telltale (Check Light),Off 12V
Fuel Pump Relay,Active 0V
Spark Angle before TDC (Top Dead Centre),-1 °CA
Ignition Coil Cyl. 1+4 (Cylinder),Load
Ignition Coil Cyl. 2+5,Load
Ignition Coil Cyl. 3+6 (Cylinder),Load
Knock Signal,Inactive
Knock Retard,0 °CA
Secondary Air Pump Relay,Inactive 12V
EGR Valve (Exhaust-Gas Recirculation),Inactive
EGR Position Feedback (Exhaust Gas Recirculation),0.80 V
Fuel Tank Ventilation Valve,0 %
O2 Sensor 1,459 mV
O2 Sensor 2,439 mV
O2 Sensor Loop 1,Open
O2 Sensor Loop 2,Open
Air/Fuel Ratio 1,Lean
Air/Fuel Ratio 2,Lean
O2-Loop 1 Integrator,128 Steps
O2-Loop 2 Integrator,128
O2-Loop 1 BLM Idle (Block Learn Map),137 Steps
O2-Loop 2 BLM Idle (Block Learn Map),58 Steps
O2-Loop 1 BLM Partial Load (Block Learn Map),125 Steps
O2-Loop 2 BLM Partial Load(Block Learn Map),126 Steps
Hall Sensor,Active
Engine Speed Pulse,Active
Engine Speed,1.060 RPM
Idle Air Control,146 Steps
IAC Integrator (Idle Air Control),139 Steps
IAC Adaptation Slope (Idle Air Control),121 Steps
IAC Block Learn (Idle Air Control),125 Steps
Desired Idle Air,26 kg/h
Actual Value Idle Air,26 kg/h
Desired Engine Idle Speed,1.070 RPM
Injection Pulse,4.5 ms
Engine Load Signal,1.7 ms
TPS Load Signal (Throttle Position Sensor),0 %
Vehicle Speed Pulse,Not Received 12V
Vehicle Speed,0 km/h
Intake Manifold Valve 1,Inactive 12V
Intake Manifold Valve 2,Inactive 12V
Torque Control,Inactive
A/C Cutoff Relay (Air Conditioning),Inactive 12V
Diagnostic Request,Inactive 5V
Could this be a failing sensor?
Re: O2 sensor?
« Reply #1 on: 27 July 2015, 13:37:17 »
Certainly no great evidence of one, biggest issue is the readings were taken before the engine was up to temperature so the system is not in closed loop, hence the O2's are doing nothing  :y
Re: O2 sensor?
« Reply #2 on: 27 July 2015, 18:13:49 »
Wait until these go CLOSED, then check again.
valliant1972
  • UK
    • omega 2.5 v6 cdx
Re: O2 sensor?
« Reply #3 on: 27 July 2015, 20:57:42 »
Hi. here's another reading.
Date and time>,13/07/2015. 19:536
hkj
Control Unit:
Identifier,0D
Battery Voltage,13.9 V
Immobiliser,Active
Mass Air Flow Sensor,0.67 V
Mass Air Flow Sensor,10 kg/h
Coolant Temperature,0.94 V
Coolant Temperature,93 °C
Intake Air Temperature,2.69 V
Intake Air Temperature,40 °C
Spark Angle before TDC (Top Dead Centre),4 °CA
Knock Retard,0 °CA
O2 Sensor 1,839 mV
O2 Sensor 2,156 mV
O2 Sensor Loop 1,Closed
O2 Sensor Loop 2,Closed
Air/Fuel Ratio 2,Rich
O2-Loop 1 Integrator,140 Steps
O2-Loop 2 Integrator,131
O2-Loop 1 BLM Idle (Block Learn Map),128 Steps
O2-Loop 2 BLM Idle (Block Learn Map),80 Steps
O2-Loop 2 BLM Partial Load(Block Learn Map),123 Steps
Hall Sensor,Inactive
Engine Speed,612 RPM
Idle Air Control,145 Steps
IAC Integrator (Idle Air Control),128 Steps
IAC Adaptation Slope (Idle Air Control),163 Steps
Desired Idle Air,9 kg/h
Actual Value Idle Air,9 kg/h
Desired Engine Idle Speed,600 RPM
Injection Pulse,2.9 ms
Engine Load Signal,1.0 ms
Thanks
Re: O2 sensor?
« Reply #4 on: 27 July 2015, 21:08:48 »
Are they both going rich/lean at about 0.5 - 1Hz?
B2 BLM looks low. Is EGR leaking?  Any other air leaks?
valliant1972
  • UK
    • omega 2.5 v6 cdx
Re: O2 sensor?
« Reply #5 on: 27 July 2015, 21:47:46 »
Its has a new EGR fitted. Ive checked all over for leaks and found nothing. All pipes are good. Replaced all the Orings to the plenum after Vauxhall left one crushed and sticking out. Also which side is bank 2?
Thanks
