handbrake travel
Started by vauxsull, 28 July 2015, 07:05:34
Quote from: vauxsull on 28 July 2015, 14:13:35
Think it'll be easier if I get garage to do it...
If you let a garage do it they will almost certainly just wind the cable up ::)
EMD
3-4 clicks on one , 7 or more on tother that's off the road but i think it must have
been mot'd like that  ::)
Omegatitis
vauxsull
MOT station I intend to use I a Vauxhall specialist so I hope he'll know what needs doing.
Quote from: vauxsull on 29 July 2015, 09:41:57
:-X :-X :-X ::) ::) ::)
But hopefully you're right :y
vauxsull
Well yes all I can do is hope... I will have a look at it though over the weekend as I'm using the pit at work...
EMD
Check the back plate fixing , they rust through .. simple fix
with a washer  :)
Omegatitis
vauxsull
Ok will do... Didn't know this was a problem area?  :y
EMD
One of my cables was dragging the ground on old elite ..  ;D
Cable had pulled through , cleaned backplate up and treated rust then put a big washer on .
Omegatitis
vauxsull
Popped into MOT station today to query the handbrake travel and he assures me 2 click's is fine so this is one thing I don't need to worry about a week today.
EMD
2 clicks you say  ::) 3 clicks on mine and it works and releases fine  :y
Omegatitis
BazaJT
Afraid I'm with DBG here.Had nothing but autos since my first Senator in the late nineties and unless parking on a hill all I've ever done is chuck it into park position,never had any problems in doing so.
Quote from: BazaJT on 01 August 2015, 17:27:54
Although we are all guilty of being lazy with parking an Auto at times, when you see how small the Park Pawl is it does change your opinion a bit  :-X ::)
EMD
Quote from: Lazydocker on 01 August 2015, 18:16:46
+1 .. its minuscule  ;D
Omegatitis
78bex
The imbalance side to side can fail the MOT for you. :(
about this time last year my handbrake felt crap, as though only one side was operating.
As I coulldn`t loosen the disc on the nearside I asked my local garage to sort it. I think they charged me £50, he noted on the bill that prior to cleaning & adjust Handbrake the imbalance was 27% side to side & that would have failed the subsequent MOT. After I picked up the car I had 3 clicks on the lever.
78bex
Just thinking about it, I suppose it depends how strong you are.
I notice swmbo uses 2 hands to release the lever sometimes.
Yer sometimes she struggles to release it & the dog on the back seat barks at it too  :y
