Pages: [1] 2 3  All   Go Down
Author Topic: modification of the oil filter (question)  (Read 10004 times)
R en R Cartechnics
  • Netherlands
  • www.renrcartechnics.nl
    • Omega V6
« on: 31 July 2015, 18:52:27 »
in this topic there is an modification for the filter.
question is this posible for the 2.6 and 3.2
http://www.omegaowners.com/forum/index.php?topic=90579.0
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: modification of the oil filter (question)
« Reply #1 on: 31 July 2015, 19:03:43 »
Yes it will work on a 2.6/3.2.
But why, the cartridge works perfectly well. :)
Hoof'land storeman.
R en R Cartechnics
  • Netherlands
    • Omega V6
« Reply #2 on: 31 July 2015, 19:09:32 »
i don't like the cartridge and i was hoping that it wil fit on my 2003 omega.
and it is leaking.  :'(
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #3 on: 31 July 2015, 19:54:57 »
Where is it leaking from did you use a genuine filter? I did mine and have had no problems at all
biggriffin
« Reply #4 on: 31 July 2015, 20:07:34 »
If fitted correctly,and torque'd correctly, pattern or genuine, wouldn't make a difference. :y
Hoof'land storeman.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #5 on: 31 July 2015, 20:13:00 »
I have had some patent ones leak because the rubber seal was not brilliant  >:( and I couldn't get it any tighter
biggriffin
« Reply #6 on: 31 July 2015, 20:53:02 »
.  Than 25nm or is it 15nm. Never had one leak yet.
Hoof'land storeman.
EMD
  • Noofhampton
    • 95t
« Reply #7 on: 31 July 2015, 20:55:13 »
That screw insert aint cheap either now , think i paid about £12 for mr stealer  >:(
Best mod ive done so far , no more stuck on caps and the spin on is cheaper  :)
Omegatitis
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #8 on: 31 July 2015, 21:44:28 »
Spin on to touch then tighten 3/4 is correct but it dripped and I tightened them over full turn so changed for another patent one and okay on both times.
« Last Edit: 31 July 2015, 21:46:48 by kevinp58 »
biggriffin
« Reply #9 on: 31 July 2015, 22:17:39 »
Think your confusing a spin on canister with the cartridge insert.
Spin is 3/4 hand tight, cartridge is inside alloy housing then torqued up.
Hoof'land storeman.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #10 on: 31 July 2015, 22:33:49 »
Nope its you as op wants the spin on filter ;)
« Reply #11 on: 31 July 2015, 23:00:28 »
Over tightening the ally cap won't make it seal any better than to the correct torque will because it seals on the O ring.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #12 on: 31 July 2015, 23:17:03 »
Okay I am not suggesting over tightening the Ali type at all as that is what destroys them mainly  >:( It seems that people have got he wrong end of the stick the OP was talking about changing the ali type to the older canister type and I asked where the leak was from after he had changed to the earlier type and said that I have had them leak before because of a faulty rubber ring and said even over tightening it didn't stop it I had to change the filter before it stopped leaking and it was on both times patent filters. Hope that clears things up.  ::) ;D
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #13 on: 01 August 2015, 00:29:06 »
i had one leak after fitting by a professional garage (ok it was national tyres).  a half moron can mess up a cartridge but even a total moron can't mess up a spin on.
R en R Cartechnics
  • Netherlands
    • Omega V6
« Reply #14 on: 01 August 2015, 05:43:05 »
i want de spin on. and forget the cardridge.
some people say that the mod.. only is for de older engines like the 3.0 and 2.5..
Pages: [1] 2 3  All   Go Up
