Author Topic: Front Brake Bleed Nipple  (Read 6888 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: Front Brake Bleed Nipple
« Reply #15 on: 03 August 2015, 19:24:43 »
sorry must type faster
RIP Paul Lovejoy
« Reply #16 on: 03 August 2015, 19:26:08 »
Mine was a serious question... Can't for the life of me remember what they're called, but essentially a six face ring spanner with an open face smaller than the side so that all six points drive the hex on the union/nipple :-\
Metrinch?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #17 on: 03 August 2015, 19:32:31 »
flare wrench?
Trust webby to get all proper n technically  :D well dun bear  :y
Hoof'land storeman.
« Reply #18 on: 03 August 2015, 19:35:46 »
The Bear wins...
Theses...  :y
« Last Edit: 03 August 2015, 19:39:12 by Harris K Telemacher »
Webby the Bear
  • Northampton
« Reply #19 on: 03 August 2015, 19:37:32 »
 ;D
need to really get a set myself  ::)
RIP Paul Lovejoy
biggriffin
« Reply #20 on: 03 August 2015, 19:56:22 »
;D
I use mole grips, when spanners fail ;D
Hoof'land storeman.
« Reply #21 on: 03 August 2015, 19:59:33 »
The Bear wins... ....
you don't need them for bleed nipples, they're obviously for unions where you need to go round the pipe  ::)
« Reply #22 on: 03 August 2015, 21:08:59 »
True enough, but they purchase better than either a traditional or ring spanner...
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #23 on: 03 August 2015, 21:39:18 »
They might be better than a normal open ended spanner, but are nowhere near as good as a ring spanner.
I have some, but rarely bother with them as I find that seized brake fittings normally need new pipes anyway.
What you're thinking of are flank drive spanners which grip on the flats. I think that flank drive is Snap On's brand, but most good brands have something similar.
« Reply #24 on: 04 August 2015, 14:33:11 »
Flare spanner?
And utterly useless on seized nipples. Been there, done it, got DTM to pick up all the pieces afterwards ;D
« Reply #25 on: 04 August 2015, 14:35:08 »
Must read page 2 before replying ;D
But still not much cop on a seized one, even with molegrips either side to reduce any spread.
deviator
  • Chesterfield
« Reply #26 on: 04 August 2015, 21:48:18 »
The biggest reason for failure is because the nipple cover has gone, water enters and it's game over.
I tend to use a 6 point socket to undo them (once wire brushed and lubed, both outside and in). I had one the other day, it took 10 minutes to get out and that did have a cover. I had to undo it a bit, spray, tighten, undo it a bit + a little more, spray..... you get the idea. It might take 10 minutes, but it's better than trying to find a rear caliper for a Pug 407 on a Sunday evening  ;D (Or anytime/any part for a Pug)
