Replacement headlamps.
Started by ted_one, 02 August 2015, 15:17:47
Steve B
Quote from: Harris K Telemacher on 15 August 2015, 21:43:43
Belts and braces... Saves whacking the washer jets with the lamp unit ;)
I take it you can unplug the Bulbs once the unit is pulled out a little,without the need to remove the Batt & air box. :y
Quote from: BIGtime on 15 August 2015, 22:03:27
All connectors can be released with lamp entirely in situ, and looms a little tight to remove lamp first.
Personally, I usually remove battery, as its so much easier for the 2 minute hassle of taking off battery.
I usually remove the trim and unbolt the light... nothing more, and nothing less, takes less time than remembering to find the car pass once you remember that disconnecting the battery can be a right pita, plus I don't then need to reset all the windows etc ;D
