Author Topic: Brake Pipe MOT Failure.  (Read 5203 times)
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« on: 03 August 2015, 20:20:21 »
Both rear pipes failed today from caliper to flexible pipe as being excessively corroded. :(
What is the recomended source for replacements please.
Re: Brake Pipe MOT Failure.
« Reply #1 on: 03 August 2015, 20:54:04 »
Make them up yourself. Or clean them up and apply a layer of grease.
Funnily enough, it should only be failed if it reduces the wall thickness by 50%. Which can only be determined for certain if it is cut in half ::)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #2 on: 03 August 2015, 20:55:58 »
If you take the old ones off most car spares shops can make you up brake pipes reasonably cheaply.I believe they charge per foot of pipe plus cost of ends.
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #3 on: 03 August 2015, 21:28:58 »
My local factor will not make up pipes any more because they cannot get insurance. However they will let me use their kit and supply pipe and nuts, just charging for the bits.
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« Reply #4 on: 04 August 2015, 14:43:11 »
Can anyone help with the details for making up these pipes?
What size pipe and what length, which union size and what flare? Plus anything else I need to know?
Thanks.
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 04 August 2015, 18:17:50 »
I just take along the old pipe for length, ends, etc., and make up a similar new one.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #6 on: 04 August 2015, 20:15:15 »
or use spray copper grease....aka ''instant brake pipe''  ;D
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #7 on: 04 August 2015, 20:16:19 »
sorry that was not constructive at all. apologies.
brake flaring kits are pretty dang cheap. give it a go at home. plenty of YT vids
RIP Paul Lovejoy
BazaJT
« Reply #8 on: 04 August 2015, 20:37:16 »
Making your own is indeed a very reasonable alternative.A roll of brake pipe[personally I'd go with Kunifer]is fairly cheap given how much pipe you get,a decent flaring tool is also a fairly cheap buy as are the ends.Most motor factors will be able to supply all you need,just remember to put the ends onto the pipe-the right way round-before forming at least the last flare,not that I've ever done that myself you understand ::)
Webby the Bear
  • Northampton
« Reply #9 on: 04 August 2015, 20:55:10 »
that's nothing. just remembering to put the fittings on before flaring is too much for some of us  :-X ::) ;D
RIP Paul Lovejoy
deviator
  • Chesterfield
« Reply #10 on: 04 August 2015, 21:15:29 »
Is no one mentioning single and double flare?
« Reply #11 on: 04 August 2015, 21:16:27 »
We've all done it ::)
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« Reply #12 on: 04 August 2015, 22:03:48 »
As the Omega is our only form of transport, I don't want to remove the old pipe without having the replacement to hand or knowing I have all the correct components to make my own. Hence trying to obtain the correct specification.
Being carless is not an option for SWMBO. :D
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #13 on: 04 August 2015, 22:12:20 »
the ends are 10mm male and female, I use the copper pipe myself :y
Figureman52
  • Nottingham
    • 2.6 CD Saloon
« Reply #14 on: 04 August 2015, 22:27:50 »
So would this do the job then?
http://www.amazon.co.uk/7-5MTR-COPPER-BRAKE-PIPE-NUTS/dp/B004O1KXOE
