Author Topic: Busted Rear Spring  (Read 3323 times)
amba
  • Medway towns
    • German V6
Busted Rear Spring
« on: 04 August 2015, 14:23:31 »
Found annoying rattle is a busted rear spring.
Europarts stock Sachs at £35 each or Boge at £43.(but on back order).
Worth waiting for the Boge or is Sachs a good reco :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Busted Rear Spring
« Reply #1 on: 04 August 2015, 14:27:57 »
Assuming its not Plod type, best replaced in pairs, have a chat with Steve at Heathrow, see if he's got some for your model from a scraper.
Last pair I had off him where good and cost around £35 for the pair from memory, mention OOF for discount or free postage Andrew.  ;)
amba
  • Medway towns
    • German V6
« Reply #2 on: 04 August 2015, 14:34:14 »
Thanks for "heads-up" Chris but with my mileage and need for a single fix would prefer buying new just to be sure .Also need them prompto so dont really want to be waiting for postage etc
Just checked and local Europarts have a pair of Sachs instock so just wanted some feed back on the better quality to opt for  :y
zirk
  • Epping Forest
« Reply #3 on: 04 August 2015, 14:36:47 »
Ok mate, I have no experience with Sachs so can't comment, just make sure there the ones for you model, ie, saloon and or self levelling or not.
« Reply #4 on: 04 August 2015, 14:38:34 »
Sachs are fine. Remember to do both sides.
amba
  • Medway towns
    • German V6
« Reply #5 on: 04 August 2015, 14:45:52 »
Thanks.
OE Self levelling was removed by previous owner when it looks like both shocks and springs were last replaced, probably due to costs.
 I will therfore opt for std springs again even though I do have a pair of decent SL shocks in dry storage as I understand STD springs will also work fine with SL shocks when the need arises to replace the shocks.
Thanks ..off to Europarts now with card in hand :(
zirk
  • Epping Forest
« Reply #6 on: 04 August 2015, 14:50:56 »
Thanks.
Check the price online first Andrew, sometimes a lot cheaper to book it than turn up and buy it  :y
amba
  • Medway towns
    • German V6
« Reply #7 on: 04 August 2015, 14:52:39 »
Just booked it online as closest store out of stock but other 6 miles away has stock.Online price is £72=00 the pair which seems reasonable to me  :-\
zirk
  • Epping Forest
« Reply #8 on: 04 August 2015, 15:02:44 »
look on carparts4less (same people) check out with discount code cp5less (-5 percent) works out around £63 a pair. :y, then go and collect from ECP.  :y
Or bump you order to 75.00, with some other bits you may need and use CP10LESS for 10 percent off.  ;)
« Last Edit: 04 August 2015, 15:06:10 by zirk »
« Reply #9 on: 04 August 2015, 15:26:48 »
Sachs and Boge are the same company (ZF).....
« Reply #10 on: 04 August 2015, 23:45:54 »
Sachs/Boge on both 2.2 and 3.2, lasting well  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #11 on: 05 August 2015, 00:23:30 »
Not gonna fit a MV6 are they  :-\
« Reply #12 on: 05 August 2015, 00:41:35 »
Depends if you keep MV6 shocks? Could just to norm all around?
B4 or maybe B6 shocks, with normal springs?
