Pages: 1 ... 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 ... 50   Go Down
Author Topic: Ok, I can officially put this 0-60 'dangle berries' to rest  (Read 229585 times)
Re: Ok, I can officially put this 0-60 'dangle berries' to rest
« Reply #210 on: 22 August 2015, 17:47:03 »
Out of interest  when the omega was tested would it have been with
Full tank
Any passengers
The British mags all test two up and with a full tank.They test in both directions in order to get an average figure.
The yank mags test one up (usually with a skinny tester)  and with the car running on vapour. They  test in one direction only. The direction the wind is blowing in. ::)
« Reply #211 on: 22 August 2015, 17:50:45 »
Full tank
Any passengers
The yank mags test one up (usually with a skinny tester if they can find one)  and with the car running on vapour. They  test in one direction only. The direction the wind is blowing in. ::)
A skinny tester?  ???  In The States?  ::)  Are you sure about that M'lud?  :-\   ;D
« Reply #212 on: 22 August 2015, 18:15:15 »
Full tank
Any passengers
There must be one or two skinny runts in the States, Sir Tig. ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #213 on: 23 August 2015, 18:10:01 »
Full tank
Any passengers
Thanks opti. But would Vauxhall have tested the omega that way? (Or whoever did the test results you find on parkers)
RIP Paul Lovejoy
« Reply #214 on: 23 August 2015, 18:26:58 »
Full tank
Any passengers
I'm not sure, Mr Bear.
I imagine they test their cars with the 'skinny guy' because it makes their figures look better.
Webby the Bear
  • Northampton
« Reply #215 on: 23 August 2015, 18:40:12 »
Thanks opti.
Just interested to know as I tested my car with just me and a virtually empty tank and the extra weight would be quite detrimental. Albeit only around four tenths . But you know me. . . I'm quite anal about this now  ;D
As Andy h says there's low fuel and one person (the driver). Anyone else confirm that for sure?
RIP Paul Lovejoy
« Reply #216 on: 23 August 2015, 19:04:14 »
It doesn't matter how GM did it, as the figures GM quote in their bumpth for the Omega are too consverative
Webby the Bear
  • Northampton
« Reply #217 on: 23 August 2015, 19:18:55 »
So the conclusion then is that my omega, for whatever reason, is slower than it should be.
RIP Paul Lovejoy
« Reply #218 on: 23 August 2015, 19:20:52 »
The conclusion is at least one of the following:
The car is shite
The driver is shite
The process used is shite
I'd suggest a 2.5 auto should be nearer to 9s than 9.5s
« Reply #219 on: 23 August 2015, 19:23:43 »
The car is shite
The driver is shite
Far be it from me to cast the first stone but I believe that Mr bear knows where the biscuit tin is. ::) ::) ::)
« Reply #220 on: 23 August 2015, 19:26:18 »
Good rear tyres also help to get the best possible traction, though less of an issue on a 2.5
ted_one
« Reply #221 on: 23 August 2015, 19:33:34 »
No more messing!! go and buy a 3.0 or 3.2 and then chill with the knowledge that you can get down the road that bit quicker than most of the boy racers in their cut and shut shit boxes :y
« Reply #222 on: 23 August 2015, 19:35:33 »
Some chavved up beemer, properly slammed, fancied his chances earlier. After the first speed bump, he was left for dust ;D
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #223 on: 23 August 2015, 19:39:50 »
I do a miss daisy over them..Owing to the lack of replacement Springs
ted_one
« Reply #224 on: 23 August 2015, 19:41:38 »
I must admit I'm a bit partial to traffic light tear up :y
Pages: 1 ... 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 ... 50   Go Up
