Welding protections
Started by EMD, 06 August 2015, 08:31:04
Webby the Bear
Quote from: Sir Tigger on 06 August 2015, 18:02:30
If you need a pair of boots, get a pair of slip on's as opposed to lace ups so any splatter falls off and can't get trapped in laces. ;)
Maybe an asbestos bollock box?  ;D
;D ;D ;D ;D
Is that attached or does DTM remove them, put them in the box during welding and refit afterwards?  ;D :o
RIP Paul Lovejoy
YZ250
Quote from: Andy H on 06 August 2015, 09:42:32
First - arc eye can cause permanent eye damage. Never strike an arc without a suitable grade of filter to protect your eyes (gas welding goggles are not sufficient).
Second - arc welding generates powerful UV rays. My first days welding (in a T shirt) left me with painful sunburn on my arms
Third - weld spatter takes the form of molten balls of flux or steel which will burn through your trainers (or down the neck of your shirt)
I wear a welding mask, leather boots, leather gauntlets and I cover all exposed skin. I use a fabric hood to keep the light out of the back of the welding mask. I would only bother with a leather hood if I was welding overhead (to keep the spatter from going down my neck)
All of the above is good advice.  :y
We wore Proban Overalls when I was on fabrication as these overalls reduce the risk of molten metal burning through. We also had to wear foreign legion style hoods.
Quote from: Webby the Bear on 06 August 2015, 17:42:45
Is this for real, Mark?  :o :o :o :o
This is very real.  :y If a bit of weld spatter goes down your shirt front you immediately and involuntarily breath in. It then drops to your waist so you breath in again, it then drops to your pants ...........and it bloody well hurts.  :o :o
On the plus side, it causes a wound and cauterizes it at the same time.  ;D
Webby the Bear
So reading between the lines DTM welded up his nob so it would swell up?
Fairly sure a cheap penis pump would be less painful  :y
RIP Paul Lovejoy
biggriffin
Quote from: Webby the Bear on 06 August 2015, 20:28:49
So reading bet the lines DTM welded up his nob so it would swell up?
You seem to have an awful lot of knowledge, or asking questions about a gentleman's tool kit ;D,, sure your not stemo, or have you decide to stalk dtm :D
Hoof'land storeman.
Webby the Bear
BG, ive got no problem with 'enhancements'. I mean using a pump took my Python from 18" on the flop to 24". You can't argue with results  ;D
RIP Paul Lovejoy
biggriffin
Quote from: Webby the Bear on 06 August 2015, 20:53:33
Stemo's taken over young bear, release that bear, stop be gone ;D
Hoof'land storeman.
Webby the Bear
RIP Paul Lovejoy
EMD
I think webby only bought his welder to walk around in this  :-X
;D ;D ;D
Omegatitis
BG, ive got no problem with 'enhancements'. I mean using a pump took my Python from 18mm on the flop to 24mm. You can't argue with results  ;D
Fixed ;) ;)
Webby the Bear
RIP Paul Lovejoy
Quote from: Lazydocker on 06 August 2015, 21:41:42
Fixed ;) ;)
Indeed, he is to young to know what inches are, so simply got carried away, uninformed...... :D :D
Sadly very true, it did actually make a very nicely quarterised hole, I will show you the scar if you like  :D :y
On this specific occasion I was welding up a rotten steam heat pipe on a coach and was sat, said molten lump dropped and found the nethers, the result was a spell of dad dancing followed by a dash to the lav.
