Author Topic: vauxhall omega 2003 2.2 petrol engine oil question  (Read 8120 times)
Andy A
  • Bristol UK
    • Omega 2.2i CD manual 2003
« on: 06 August 2015, 10:48:59 »
I've been using GM 10w40 semi in mine since I got the car.
Is anyone using or swopped over to GM 5w30 Dexos 2 engine oil from 10w40 semi and are there any advantages or disadvantages in using this instead?
Thanks
mandula
  • Finland
    • Opel Omega -03, Z22XE man
Re: vauxhall omega 2003 2.2 petrol engine oil question
« Reply #1 on: 06 August 2015, 16:39:48 »
I swapped to use 0W-40 from 5W-30 because here in Finland it is often cold starts and vent lifters kept noise long time after cold starting the engine. Also I noticed approvement on oil consumption when changed to use 0W-40.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 06 August 2015, 18:57:47 »
I would GUESS that changing from the GM semi to the full fat MAY cause leaks as the new full fat stuff is more slippery. And if you have a slight weeping somewhere that wasn't apparent using semi, the new stuff may find its way out.
Try it. Change back if you notice any leaks. Or fix the source of the leak. If you can be arsed  :y
RIP Paul Lovejoy
« Reply #3 on: 06 August 2015, 19:57:37 »
Slippery oil.......is this a good idea? ::) ::) :)
« Reply #4 on: 06 August 2015, 20:23:13 »
That'll never catch on... ;D
Andy A
  • Bristol UK
« Reply #5 on: 07 August 2015, 19:10:55 »
I think I will stay with the tried and tested GM 10w40. No leaks at the moment.  :y
I've never seen a 20 liter drum of GM 10w40 before. Is this genuine GM oil and what is the difference between Trade Club oil and non trade club?
http://www.ebay.co.uk/itm/20LTR-DRUM-10W40-ENGINE-OIL-VAUXHALL-GENUINE-SEMI-SYNTHETIC-PETROL-DIESEL-/390686523527?pt=LH_DefaultDomain_3&hash=item5af6bb4087
« Last Edit: 07 August 2015, 19:14:19 by Andy A »
« Reply #6 on: 07 August 2015, 22:00:10 »
I've been using GM trade 10/40' in all my Omegas since 2005, don't see advantage in 5-30 with English climate.
10/40 is very well tried and tested here, with great results  :y
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #7 on: 08 August 2015, 00:41:38 »
5w40 fully syn :y
Andy A
  • Bristol UK
« Reply #8 on: 08 August 2015, 09:50:44 »
Tunnie does the oil in the link look like genuine TC oil?
« Reply #9 on: 08 August 2015, 10:07:21 »
Looks genuine Andy. Might be worth a call to "Drive" in Avon Street to get a trade price though
Andy A
  • Bristol UK
« Reply #10 on: 08 August 2015, 11:07:51 »
Rob, just phoned Drive and they quoted £22.50 + VAT for 20 liters 10w40. That sound to cheep to me.
Then I asked about 20 liters of Antifreeze and was quoted £48 + VAT.  :o
« Last Edit: 08 August 2015, 11:15:57 by Andy A »
« Reply #11 on: 08 August 2015, 11:11:14 »
Blag "TC" and make sure it`s the right price
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #12 on: 08 August 2015, 11:19:41 »
Buy it. That's cheap.
Hoof'land storeman.
Andy A
  • Bristol UK
« Reply #13 on: 09 August 2015, 10:38:20 »
I will phone Drive again tomorrow and double check price. If it is that cheap then I will be getting 40 liters.  :y
Is there a use by date on oil?
biggriffin
« Reply #14 on: 09 August 2015, 11:50:05 »
well its been in the ground a few million years, and hasn't gone off ;D
Hoof'land storeman.
