Welding steel
Started by EMD, 07 August 2015, 10:54:47
minifreek
You can weld bodywork with a ARC welder :) I did it to my Vectra when i welded a bonnet extension onto the bonnet :) and also to the Omega's rear arches when I replaced them a couple of months ago...
I have both ARC and MIG welders, I prefer the MIG as it is a lot easier to use than the ARC, especially on thinner stuff. I'll be welding up a baseplate soon for an antenna tower I have so it will need to be welded using the ARC as its thicker steel and will need to be a strong weld.... It will be made from 3-5mm wall box section and 3-5mm plate steel... depends on what I can get hold of at the time of purchase...
I wouldn't say I can weld but can join 2 pieces of metal together using the welding process.... The welds may not be neat but are strong, I tested them....
D.I.L.L.I.G.A.F...
MIG actually produces a stronger weld than ARC........if done well.  :y
Welding for making stuff is fine. Any car that requires welding should be scrapped.
EMD
Quote from: STEMO on 01 September 2015, 14:30:05
My Mk5 Cortina was held together with welds for years  ;D
Quote from: minifreek on 01 September 2015, 09:56:19
I can see that its possible to arc weld body panels if your careful . Its the heat transfer you got to watch though  :(
Omegatitis
