Author Topic: Cannot undo oil filter cartridge on new 2.5 V6 - any suggestions?  (Read 5038 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
2.5 V6 petrol estate, bught in Clacton, came from Portugal. I am sorting this car, have drained the oil, cannot shift the oil filter cartridge. I am aware if I pull too hard it the whole thing will rotate. Any tips would be greatly appreciated.
Re: Cannot undo oil filter cartridge on new 2.5 V6 - any suggestions?
« Reply #1 on: 09 August 2015, 13:20:07 »
Only just try to hold the main assembly and undo the cap.
Its likely the assembly will move, and thus will need removal and retightening.
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 09 August 2015, 14:41:13 »
Now I have broken it. Applied leverage to the central square socket, and the cap of the canister split. It is now leaking oil. Clearly I have to get the cap off off now - saw, drill, whatever - to get access to the haxagon that holds on the canitser to the crankcase. What is the best way of doing that?
« Reply #3 on: 09 August 2015, 14:44:36 »
As you have (now) found out, you shouldn't use a ratchet in the end of the cap, but a 24mm (from memory) socket on it.
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 09 August 2015, 14:55:12 »
How true. I had tried a 24mm socket, but it tended to come off the hexagon. 3/8" plug seeemed more secure! I did not foresee the risk of splitting the cap - silly me.
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 09 August 2015, 15:18:50 »
How do I best get that cap off to unscrew the 28mm nut to remove the filter canister? Car is above the pit, I have a power drill, also an airline saw I have never used with a very short blade. Pic follows.
https://www.dropbox.com/s/6qk17kl1etnmqkd/canister50%25.jpg?dl=0
EMD
  • Noofhampton
    • 95t
« Reply #6 on: 09 August 2015, 15:52:44 »
You did the same as me and mine split , i just put a bit more leverage on the cap and it split enough to turn by hand . This is why i will never go back to these cartridge filters , too much faffing about . I did the spin on conversion and never looked back  :y
Use a chain or filter strap on the housing if its spinning.
The cap is knackered now and stealers wanted £35 ish for a new cap unless you can source a second hand one .
« Last Edit: 09 August 2015, 16:03:14 by EMD »
Omegatitis
terry paget
    • 3 Astras 2 Vectra
« Reply #7 on: 09 August 2015, 18:09:33 »
Thanks EMD, your post gave me hope. Sadly, mine would not turn in its damaged form. I attacked the cap with drill and saw, then hammer and chisel, and removed most of the cap and the filter. I can now feel the 27mm hexagon, but failed to turn it with he tools I have, strange because I did it 2 years ago when I changed an exhaust manifold. Tomorrow I shall seek a deep 27mm socket or a 2"" extension.
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #8 on: 09 August 2015, 19:32:10 »
when i changed to spin on i kept the cartridge for a while (which never seized up despite useless national tyres) but no one seems to want them :(  i suppose anyone having to replace a broken cartridge unit will likely change to spin on.  have a look at the change guide http://www.omegaowners.com/forum/index.php?topic=90579.0 it will help you to remove the cartridge unit
deviator
  • Chesterfield
« Reply #9 on: 09 August 2015, 20:01:20 »
Just in the last couple of hours had this myself, as suggested here.... (OK 24mm 6pt socket on 3ft breaker bar.)
Did the job great  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #10 on: 09 August 2015, 20:57:30 »
The filter was filthy, probably completely clogged. I wonder when it was last changed. I can imagine garages doing a service would change the oil and leave the filter if tricky to change, and this may have gone on for years.
kevinp58
  • kent
    • 2002 3.2 elite
« Reply #11 on: 09 August 2015, 23:40:03 »
 :y that's the way to go.  ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #12 on: 10 August 2015, 21:25:08 »
Gentlemen, thanks for all help and advice. This forum is wonderful. Remains of cartridge removed, spin on pipe installed with filter. Pic follows.
I note the crank sensor is original, 15 years and 159000 miles. I wonder how much longer it will last?
https://www.dropbox.com/s/4i4ozgot3nfmfzv/filter60%25.jpg?dl=0
« Reply #13 on: 10 August 2015, 21:28:18 »
Probably not very, now that you mention it... ::)
Glad otherwise sorted though :y
deviator
  • Chesterfield
« Reply #14 on: 10 August 2015, 21:30:42 »
Glad you've got it sorted.
Me love you "long life"  ::)
