Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Omega losing power  (Read 19928 times)
Kate
  • Cornwall
    • Drives people mad
Re: Omega losing power
« Reply #45 on: 16 August 2015, 17:25:07 »
It's frustrating when there are lots of possibilities. >:(
I got some k-seal and that seems to have stopped the coolant leak. I know it's not the best solution but it was the only thing I could afford. :-\
Didnt we talk about this last time? >:( ::) :)
 ;D
That stuff is lethal  :-X
Well I drank the whole bottle and I'm fine. Can't have a pee though. ;D ;D ;D
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #46 on: 16 August 2015, 18:09:43 »
A big thanks to Monsieur Guffer for having a look at her today. :y
It turns out that the radiator has a leak on the top right plastic-looking bit and this might have been spraying coolant onto the battery and causing a short.
There was no sign of a petrol leak.
I'm going to look for a new radiator so any suggestions as where to get one from would be much appreciated.
Thanks again MG. :y
It was just the coolant residue on the battery itself which made me think of this.  The leak is on the top NHS of the rad, a crack in the plastic.  Under idle and it mostly just trickles but we saw a huge amount come out and I can imagine that under load that coolant would spray up.   This spray would hit the lpastic trim which kindly seems to angle the spray on to the battery.
This is just supposition at the moment but putting everything together (including that the k-seal had stopped it for a bit) lead me to this idea.  I think it best to deal with that possibility before going down rabbit holes unecessarily.
So in my best bodge we have stuck a piece of plastic sheet over the battery and stuck it down while Kate finds a new rad.  If it doesn't happen again while that sheet is in place and after the rad leak is fixed then I think we can be fairly sure that was the cause.
If it does happen look at the battery light on the dash and pull over as soon as you can to check the moisture around the battery. :y
flyer 0712
« Reply #47 on: 16 August 2015, 21:05:59 »
Hi Kate...does your radiator have an oil cooler incorporated in it,,????
« Reply #48 on: 16 August 2015, 22:50:36 »
Kate
  • Cornwall
    • Drives people mad
« Reply #49 on: 16 August 2015, 23:05:59 »
I don't know.
EMD
  • Noofhampton
    • 95t
« Reply #50 on: 16 August 2015, 23:15:48 »
 ;D
 ;D
Just fitted one of Theses...
http://www.ebay.co.uk/itm/281089791116?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Nothing more to say really ;)
Woh thats cheap as chips !
Omegatitis
« Reply #51 on: 16 August 2015, 23:21:31 »
I don't know.
Either has two metal pipes connected to the driver side or two metal pipes going over the top edge, about six inches from driver side end ;)
Is actually irrelevant as the rad I linked to has the mounting points for both :y
Gaffers
« Reply #52 on: 17 August 2015, 05:10:44 »
I thought all autos had the oil cooler element? :-\
« Reply #53 on: 17 August 2015, 05:17:23 »
They do :y the question is where... Earlier cars have it in the main rad, later ones have a separate one sat between the rad and condenser...
« Reply #54 on: 17 August 2015, 09:54:35 »
I think the separate transmission cooler came in with the 2.6/3.2?
Gaffers
« Reply #55 on: 17 August 2015, 11:02:37 »
Kate's is def a 2.5, could be W plate IIRC
« Reply #56 on: 17 August 2015, 12:36:13 »
Pretty sure that would have it integrated with the coolant radiator. Doesn't really matter, as you can use the radiator with the cooler on any model. Just don't connect it up. :y
Kate
  • Cornwall
    • Drives people mad
« Reply #57 on: 17 August 2015, 16:27:36 »
Yes it's a 2000 2.5 W plate.
Would one of those eBay radiators be any good?
« Reply #58 on: 17 August 2015, 16:30:22 »
Yup, perfect for ANY V6 Omega :y
Kate
  • Cornwall
    • Drives people mad
« Reply #59 on: 17 August 2015, 20:26:06 »
I think I'll get one of those then, thanks. :y
Pages: 1 2 3 [4] 5  All   Go Up
