Author Topic: What's that noise ?  (Read 2571 times)
EMD
  • Noofhampton
    • 95t
What's that noise ?
« on: 14 August 2015, 16:46:48 »
Nearside rear tap tap tap over slight bumps , goes away after a few miles  ??? Shocker  :-\
Omegatitis
tidla
  • solihull
Re: What's that noise ?
« Reply #1 on: 14 August 2015, 16:47:50 »
shock mount needs tightening.
(might edit again in a minute)
EMD
  • Noofhampton
    • 95t
« Reply #2 on: 14 August 2015, 16:48:36 »
drop link.
Ah yes could be so  :y
Omegatitis
« Reply #3 on: 14 August 2015, 16:49:41 »
drop link.
Not on the rear it won't be :y
EMD
  • Noofhampton
    • 95t
« Reply #4 on: 14 August 2015, 17:00:15 »
Omegatitis
« Reply #5 on: 14 August 2015, 17:30:44 »
Shock top mounts or rear subframe donuts, plus things like exhaust hangers, heat shields... :y
Could even be the locking wheel nut key in the spare wheel well... not to mention summat left loose when you weren't fitting the rear blind :y
« Reply #6 on: 14 August 2015, 17:48:51 »
Sounds like what I have, be rear shock bush. I took shock bolt off, shock all good in operation.
I've ordered the kit, will post up details at the weekend.
EMD
  • Noofhampton
    • 95t
« Reply #7 on: 14 August 2015, 17:52:17 »
Noise was there before the blind install . Ive noticed it more since the new quiet diff has been put in , i used to have the radio up high to hide the diff noise  ::)
Omegatitis
    • 530D M Sport, 330i Coupe
« Reply #8 on: 14 August 2015, 18:14:18 »
I used to have the radio up high to hide the diff noise  ::)
Been there!
