Author Topic: Car not starting  (Read 1993 times)
artsoul_no1
  • sidcup, kent
    • Omega CD 2.6 v6 2002
Car not starting
« on: 15 August 2015, 16:21:19 »
Changed auxillary belt last week and afterwards car wouldn't start. Checked pulleys and belts and they were all moving as thy should
Disconnected battery for an hour when reconnected the car started up straight away no problem. today drove car this morning no problem went to move car an hour later wont turn over again. Over last few weeks car has been hesitant to start maybe once or twice but usually spaced days or weeks apart.
I'm thinking crank sensor i felt behind engine where i think the sensor plug is and found a hose that isn't connected to anything it was pointing downwards, is this a drain hose for something it doesnt look like it ever had a clip on it.
This is it pulled up from under scuttle
http://i1339.photobucket.com/albums/o718/artsoul_no1/pipe_zpsundonzp2.jpg
This is where it goes to (pipe starts top left in picture)
http://i1339.photobucket.com/albums/o718/artsoul_no1/plug%201_zps6zy4sehr.jpg
Also is this the crankshaft plug and can anyone tell what type it is before it is removed (car is a 2002 2.6)
http://i1339.photobucket.com/albums/o718/artsoul_no1/plug%202_zpsd3znmetq.jpg
Appreciate any help
Thanks
artsoul_no1
  • sidcup, kent
Re: Car not starting
« Reply #1 on: 15 August 2015, 16:24:18 »
Apologies these are the images
amba
  • Medway towns
    • German V6
« Reply #2 on: 15 August 2015, 16:37:26 »
The pipe you are showing is the autogearbox vent pipe and isnt ment to connect to anything as it is a vent pipe.
It should run around the back of the engine in the exact position as you have discovered and allows the gearbox to vent to atmosphere..perfectly normal.
We had this conversation last week after the symptoms you described and I advised you to consider replacing the crank shaft sensor as the faults you were describing were classic.Sounds like it has now given up on you...time for a new one I think . ;)
The plug you have located is for the injectors not the crank shaft sensor as it has a much thinner black sleeved wire going into the plug/socket.It will be either clipped up behind the back area of # 6 plug probably onto a metal bracket unless in a previous life it has been busted off.
powerslinky
« Reply #3 on: 15 August 2015, 18:20:07 »
I'm with amba on this one  . . crank sensor most likely .    ;)
artsoul_no1
  • sidcup, kent
« Reply #4 on: 15 August 2015, 18:51:17 »
Thanks Andrew and Al
Crank sensor change it is then
