Author Topic: '02 2.2 Petrol cambelt change  (Read 1803 times)
glosdave17
« on: 16 August 2015, 11:02:53 »
Looking to change the cambelt and was wondering if there's anything that may bite before starting?
Seems fairly straight forward from what details I can see on OOF. Obviously will replace the aux belt at the same time.
Thanks
Re: '02 2.2 Petrol cambelt change
« Reply #1 on: 16 August 2015, 11:17:43 »
Do you have a locking tool? :y
« Reply #2 on: 16 August 2015, 11:18:42 »
Oh you'll need to do the water pump too.
Where are you in gloucestershire? My home county :y
« Reply #3 on: 16 August 2015, 12:28:14 »
Nothing too strenuous. Need to replace the "cambelt kit" (cambelt, idlers and tensioner) and the waterpump (as its cambelt driven). Therefore, you need to do coolant as well.
About an hours work on the 2.2, double that if its the first time you've done it.
Photo exactly how the waterpump sits before removal, as its not always obvious how it goes back :)
T.m.f
    • 4wd
« Reply #4 on: 16 August 2015, 12:52:39 »
Replace aux belt if its not been changed aswell,also grease up aux tensioner bearing aswell  :y
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #5 on: 16 August 2015, 13:30:13 »
And get tool well in the water pump bolt before trying to undo or the chew  :y
« Reply #6 on: 16 August 2015, 15:33:54 »
Only small faff is making sure water pump sits right, other than that straight forward.  :)
