Author Topic: Disc error message on CCRT CD player  (Read 8857 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: Disc error message on CCRT CD player
« Reply #15 on: 20 August 2015, 17:22:17 »
Thanks for advice gentlemen. Testing this morning, performance is indeed disc sensitive. I put in 6 discs, initially all 6 worked, then one, a Sidney Bechet disc.failed. I put it into a different slot, it loaded twice, 3rd time it failed again. Other 5 were fine.
Changer is quite useable, indeed I am impressed that the whole system works as well as it does after 15 years. Sound quality is good..
Bar code number is 7 607 797 321 Dave. Have you idea of the cost of a new laser, and is fitting a DIY matter?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #16 on: 24 August 2015, 11:56:11 »
Genuine Blaupunkt lasers now discontinued, which is why we are unable to assist
Aftermarket lasers can very from £30 ~£80 but you will need to get someone to fit it and then calibrate it for you, as this model requires some extensive tweaking to set the laser up correctly
Radio & Decoding Technician
www.dndservices.co.uk
terry paget
    • 3 Astras 2 Vectra
« Reply #17 on: 29 August 2015, 08:30:13 »
Thanks Dave. I have been running it in magazine Random mode for 2 weeks now, and disc now is now deemed missing. I can live with this. Buying a 15 year old car I expect a few imperfections.
I used to have a lens cleaning disc. Do these work, and might it help in this cse?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #18 on: 29 August 2015, 10:09:47 »
Lens cleaning should only ever be done with a lint free cotton bud, and very carefully. Those cleaning discs just knock hell out of the focus coils, but as yours is so knackered now, then probably isn`t going to make it any worse.
terry paget
    • 3 Astras 2 Vectra
« Reply #19 on: 29 August 2015, 11:46:20 »
I have never found lens cleaning discs effective on other CD readers. Is gaining access to the lens reasonably easy with the unit on the bench?
