Author Topic: Connecting to the CDC line on an Ncdc unit  (Read 9044 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Connecting to the CDC line on an Ncdc unit
« Reply #15 on: 24 August 2015, 17:17:48 »
Confused dear? Me dear? No dear. I don't know what you could possibly mean... ;D
Will use the amp outputs from aux headunit, so aux levels will be controlled/adjustable from the menu on the aux h/u... The Bose amp should then take care of the rest :y
Na, you've confused me now  ;D, I assume you mean, when you say Amp outputs, your talking about pre amp, line level, RCA output rather than speaker outputs.  :y
« Reply #16 on: 24 August 2015, 17:23:05 »
Indeed :y
    • 530D M Sport, 330i Coupe
« Reply #17 on: 24 August 2015, 18:09:47 »
Andy's top tip of the day... Always use screened cable when intersecting that method of audio input  :y
« Reply #18 on: 24 August 2015, 18:11:03 »
And learn to solder, unlike our Ruski friend :o
« Reply #19 on: 24 August 2015, 18:19:10 »
Not only that, he needs to be introduced to the concept of heat shrink tubing!
« Reply #20 on: 24 August 2015, 18:39:02 »
Well hopefully this will pass muster then...
« Reply #21 on: 24 August 2015, 19:00:01 »
And all back together...
« Reply #22 on: 24 August 2015, 19:17:54 »
Looks good to me Al.  :y
Question, does your 'other' HU have a Line in facility?
« Reply #23 on: 24 August 2015, 19:22:45 »
It does :y Will be fed by 2/3 disc changers and DVB tuner...
« Reply #24 on: 24 August 2015, 19:34:44 »
I see :y
I was thinking you could, in theory, run the CDC output into the line in on the 2nd HU, the benefit being that you select that source from the second HU if that is your main AV control centre.
« Reply #25 on: 24 August 2015, 22:41:05 »
Just need some power now...
Hmmm... I wonder ::)
« Reply #26 on: 25 August 2015, 07:29:56 »
If your running another Head Unit I think I would take the power feeds off the feeds fir the ISO.
« Reply #27 on: 25 August 2015, 09:31:05 »
Separate feeds it is then... :y
mka306
« Reply #28 on: 25 August 2015, 10:47:45 »
Rather you than me pal looking at that, impressive soldering to say the least.
« Reply #29 on: 25 August 2015, 18:04:52 »
Thanks :y
All working as it should, threw a battery on just to test it, but now having a bit of an argument with myself as to whether I should carry on with the dvd/dvb install or just run with a Bluetooth head unit... Providing it has the bus control and audio amp outputs ::)
