Author Topic: Malfunction indicator  (Read 2221 times)
Kieran
  • Dorset
« on: 25 August 2015, 12:16:22 »
Hello everyone
On towing the caravan home the other day the warning light came on. Car is running fine apart from the spanner light illuminated. Took the car for a drive yesterday and although the light went off it soon came back on again. Did the pedal test and code 0650 came up indicating Malfunction Indicator Control Circut/High/Low/Open.
What does this mean and how do you rectify it.
Thanks for looking. Car is 2.6 CDX Estate.
Kieran
Re: Malfunction indicator
« Reply #1 on: 25 August 2015, 18:54:52 »
What other codes?
Kieran
  • Dorset
« Reply #2 on: 25 August 2015, 19:56:41 »
Just checked. Didn't think of looking for other codes. 0325 has also come up indicating Knock sensor 1circut low.
Kieran
  • Dorset
« Reply #3 on: 25 August 2015, 20:02:18 »
Crank sensor was recently changed a couple of months ago using genuine parts. Could this cause a faultly signal. Car seems to be running fine with no noticeable problems.
Kieran
  • Dorset
« Reply #4 on: 26 August 2015, 21:12:52 »
Anyone know what the problem could be. :y
« Reply #5 on: 27 August 2015, 19:03:37 »
That's the fault then.  Although always worth clearing the codes, and see what comes back, if possible.
