Timing belt kits + wishbones
Started by Gaffers, 27 August 2015, 10:07:29
Quote from: Monsieur Guffer on 27 August 2015, 17:24:27
I think new bushes with original wishbones also means full geo, surely?
As for gollum, I know that this is not his OOF alter ego ::) ;D
It does indeed, and also relies on your existing wishbones being in a suitable condition to rebush... This point cannot be relied upon. ;)
In an ideal world, buy the Atp arms, rebush them as you see fit, btw ball joints are less than a £10ea, then fit along with set up...
As the rest of the car is an unknown, throw the cheapies on box fresh and assess/fully refurbish the current ones ready for replacement down the road :y
I'd go down the refurb route every time, if that's possible.  Ignore the tat that is bundled, as I've learnt my lesson, and only use GM TREs, as the cost/hassle of geo far outweighs a few quid saved on parts.
Gaffers
Quote from: TheBoy on 27 August 2015, 18:12:30
Tbh I am leaning that way too.  When your commute to work takes 12 hours a week time becomes very precious :y
Quote from: Monsieur Guffer on 27 August 2015, 18:13:41
I know. Annoying, my commute is less than 25 miles each way, but when the kids go back, its back to >1hr each way :(
Either scenario will likely need a geo
Gaffers
Quote from: TheBoy on 27 August 2015, 18:15:14
That's without counting the time spent actually going to/from the office.  Add another 5 hours :(
Having thrown genuine GM wishbones away in the past (you live and learn  ::) ) I now use Lemforders but fit, well re-use, poly bushes in the front. Result of this is that both cars have Lemforder wishbones with polys and I have a used pair ready for refurbishing...
Webby the Bear
Quote from: Harris K Telemacher on 27 August 2015, 11:48:25
Given as the car may/may not be a keeper... ::)
These... will see you sorted :y
https://www.atp-autoteile.de/group/1150201/product/15808/18846/details
And before anyone bleats... for €81 you could do far worse ;)
Cambelt is as cambelt does, so the Gates kit still seems to be the item of choice...
I have these bones, drop links and TREs and they've lasted well over a year so far and no issues yet. I got under the car the other day and they still look good with no play  :y
RIP Paul Lovejoy
ted_one
Same for me,all three cars have ATP fitted,but I won't be doing many miles, maybe 3k a year so I won't be the person to give any real feed back on them ::) Other than they seem to fair OK on the shite roads around  Wo kingham ::)
biggriffin
;D
Now with all this talk, that should fetch him out, chuck a few winter tyres on this,to really get the thread banging ;D
Hoof'land storeman.
Can't post if you're not allowed ::)
Diamond Black Geezer
Only on 6 months so far of combination of cheapy wishbones poly'd and GM'd to the hilt, and ATP everything else, so too early to say, really. 6k miles covered, however. Happy with ATP and my setup so far  :)
I think I must have bought a 'Friday' set of wishbones from ATP.  ::)
I fitted them straight from the box and when the front bushes started to fail after 8 - 9000 miles I fitted poly bushes, which improved things but it still wasn't right.  When I removed them to replace the rear bushes with Vx bushes, I saw that the weld around the rear bush casing had started to crack.  :(
Only slightly, but it wasn't going to get any better and I lost confidence.  ::)
Gaffers
Hmm, not sure on the engine number and there are 3 choices.  :-\
From memory if I order the wrong one I can swap the tensioner backplates instead, right?
biggriffin
Quote from: Monsieur Guffer on 02 September 2015, 10:42:27
Correct.
Hoof'land storeman.
