Pages: 1 [2] 3  All   Go Down
Author Topic: another rainsensor auto dimming mirror question  (Read 12489 times)
Re: another rainsensor auto dimming mirror question
« Reply #15 on: 27 August 2015, 23:39:44 »
If the shell is stripped, and that is all you have, then that is all you have :-\
Guide is in the maintenance guide section :y
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #16 on: 27 August 2015, 23:41:59 »
thats a bugger thought it was a standard loom was hoping anyway. thanks anyway al
« Reply #17 on: 27 August 2015, 23:48:26 »
No probs ;)
As an aside, where didyou get your screen from? Still having an argument with Autonoglass...
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #18 on: 27 August 2015, 23:57:04 »
got a screen from work. i work for national windscreen. it cost me 150 quid + vat
« Reply #19 on: 28 August 2015, 00:00:46 »
:y been waiting since May >:( :-X
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #20 on: 28 August 2015, 00:02:33 »
When I did my autodim I found that the plug in this picture has the correct wires. +ve -ve and reverse switch. Easily double checked with a meter
think this is the sensor wire
https://www.dropbox.com/sc/03925f3iqft6btp/AACebp4Thb0vR24JGOl15KCSa
Using the picture at the bottom of the guide I located the wires in the mirror, removed both plugs and soldered the wires to each other. Works a treat dims and disables when in reverse.
Link to guide http://www.omegaowners.com/forum/index.php?topic=90639.0
Sorry cant help with the rainsensor
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #21 on: 28 August 2015, 00:03:03 »
pity your never up this way i can get another
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #22 on: 28 August 2015, 00:07:06 »
thats a better pic of what i got. thanks for getting the mirror sorted mate just need to fudge the sensor... somehow :y
would the wire up there be a ribbon cable for the sensor?
« Last Edit: 28 August 2015, 00:09:01 by davieboy0312 »
« Reply #23 on: 28 August 2015, 00:21:39 »
If the headlining is out and you haven't seen it, then no :'( All.runs up.The passenger a pillar...
The bigger plug could be the mirror one then, in which case you can swap the wires into your Later mirror :y
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #24 on: 28 August 2015, 00:26:20 »
Oh well back to manual wipers  :'(
« Reply #25 on: 28 August 2015, 01:18:09 »
Vw99 relay could be the next best thing ;)
Besides, the car willstill look liie it has a sensor fitted, which is nice 8)
« Reply #26 on: 31 August 2015, 12:35:19 »
As that option was not an option in 2000, there won't be any wiring in the loom for it. So that's why you can't find it.
TBH, its really, really, REALLY not worth the effort.
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #27 on: 31 August 2015, 12:38:01 »
Already got the adjustable wipers will stick with that  :y
  • Auckland
    • Mazda MPV
« Reply #28 on: 31 August 2015, 13:30:23 »
+1
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #29 on: 31 August 2015, 15:50:44 »
Seconded, yet again.
I will say it Again, "o look its raining, I shall turn my wipers on, o look its stopped, I'll turn my wipers off"
 Simples
Hoof'land storeman.
Pages: 1 [2] 3  All   Go Up
Page created in 0.056 seconds with 20 queries.
