Modified SL pump bracket for LPG ECU?
Started by VXL V6, 30 August 2015, 17:28:43
Quote from: Harris K Telemacher on 31 August 2015, 22:05:45
Difference between 300 and 300+ :-\
Mine is a plus, which means Lazydocker's estate will have a plus as well.
That said, the looms seem to vary tremendously.
Quote from: TheBoy on 01 September 2015, 17:21:14
That picture is my saloon - a 300 ;) Plus an 8 cylinder version because he didn't have any 6 at the time ::)
OK, here's my initial attempt.
I've cut the pump bracket opening a little larger to accommodate the connector plug, the 90 degree brackets are secured to the frame with a bolt, washer and nylock nut. The idea is to bolt a horizontal strip across these (with a countersunk headed bolt, washer and nylock nut) the bolt the ECU to the strip. Presume this would be COP11 compliant?
If it physically fits, that'll be fine (and COP11 compliant)
Once I've sorted out the horizontal strip i'll temporarily mount the ECU in place and offer it into position and see what's what.
Funnily enough, the ECU isn't really looked at for COP 11... Probably why some companies just stick it in the scuttle loose :o ::)
