Author Topic: Part number help  (Read 2769 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Part number help
« on: 30 August 2015, 22:20:28 »
I need one of these vacuum connectors as mine has a slight crack, Are they available at VX if so do they have a part number or are they readily available somewhere else? I've had a look but can't find anything.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Part number help
« Reply #1 on: 30 August 2015, 22:32:20 »
Something like this cut to size ?
LINK / LINK
« Last Edit: 30 August 2015, 22:34:18 by Mr.OmegaMan »
« Reply #2 on: 30 August 2015, 23:21:39 »
TB has recently been posting about these
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #3 on: 31 August 2015, 16:56:24 »
It was a wanted post if I remember correctly though  :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #4 on: 31 August 2015, 18:13:35 »
Anyone?  ::) ;D
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #5 on: 31 August 2015, 21:58:26 »
Are we looking at the bagpipe connector to/from the vacuum switch? I am not clear which connector you seek.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 31 August 2015, 22:38:57 »
As in the picture..
Inside the highlight circle the rubber vacuum piece, Not sure what its proper name is hence why I thought it best to add a picture. It doesn't seem to be affecting performance but it's on its last legs.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 01 September 2015, 09:09:44 »
As said TB been one this for past two weeks, lots of clinkys in that thread,.
Hoof'land storeman.
LC0112G
« Reply #8 on: 01 September 2015, 10:52:20 »
EPC isn't very clear on this sort of thing. It could/might possibly be 90572322. If they're still available they'll probably be in a pack of 50, cost £1 each, and the dealer will try to make you buy the whole pack. If you want to take the risk fair enough, but I suspect most of us would be down the scrap yard for a good look-see, and get the most suitable part from there.
These rubber elbows are used in Carltons and perish for a past time - causing all sorts of issues. The ones I got were off the ends of the vacuum advance pipes for old proper Austin Minis. A good motor factors should stock the sort of thing.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #9 on: 01 September 2015, 15:18:50 »
There's no definitive answer here as far as I can see though.
http://www.omegaowners.com/forum/index.php?topic=132168.msg1693696#msg1693696
If I at least knew if it was a 3.0mm or 3.5mm etc.. That would be helpful  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #10 on: 04 September 2015, 17:27:25 »
Ordered a few different types/sizes and found this one to be best, It fits like a glove and appears to be of decent quality with plenty of flex.  :y
http://www.ebay.co.uk/itm/400470913426?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
