Keyed!
Started by Lawman, 25 November 2006, 19:15:30
Lawman
Quotethats bad news lawman - but what do you expect from cleland? used to live ear  :-/ hope the touch up advice helps mate  :y
Hey Mark, it was parked in Newarthill, so nananana  ;D
Markie
;D least you can still laugh about it mate - credit to you  :y  :)
Lawman
I'd have to laugh, or I'd cry! I've had no luck with this car at all!!
Had it a whole year this week or last. Purchased from Watsons of Airdrie for £2700
Next few weeks went fine, till a Taxi hit the back of me in George Square one night, £750 worth of damage....took months to sort out...taxi company ended up paying.
A long dent appeared on my back door, really sharp, white paint exchanged.
Someone scuffed the corner of my front bumper
MAF sensor went during the summer, ran fine, really intermittant, fault only came on when I booted it sometimes. Got it fixed then the Crank sensor went, leaving me stuck right at the end of the M74!
Then this week for the MOT it needed new rear brakes and a handbrake cable!
My last corsa i had for 6 months, needed a center section and petrol!! I miss it! :-[
RonaldMcBurger
terrible! Unbelievebale! Appalling!  Firstly, they can't scratch staright but then they pick a GLS!!!! Com,e on vandals, if you are going to scratch the car, do it proerly and pick a CDX at least!
Muppets!
Now, hopefully that has cheered you up almost as much as cunjouring up an image of Margaret Becket pole dancing whilst Anne Whiticombe does a bit of sword swallowing in the crowdf (if you know what I mean!)
Yes the tablets are strong tonight, but at least you didn't suffer -seeing those two perform! I'd better not mention the Alsation and lady Thatcher then!
HTH
Lawman
Quoteterrible! Unbelievebale! Appalling!  Firstly, they can't scratch staright but then they pick a GLS!!!! Com,e on vandals, if you are going to scratch the car, do it proerly and pick a CDX at least!
Muppets!
HTH
Haha, A GLS Corsa is like royalty compared to everyone's "envoys" haha jealous buggers!
Thanks for those images...hope I sleep well tonight with no nightmares!! :-/
Martin_1962
SOrry to hear about the damage, I hope you can get a decent repair. I also hope you can catch the miscreants
Lawman
QuoteSOrry to hear about the damage, I hope you can get a decent repair. I also hope you can catch the miscreants
Will never catch them, scum of the earth haha, even if I did catch them, there's nothin I could do! Couldn't bring myself to key someones car....doubt they even have a car...scumbags :-/
Markie
And good evening to you Ronnie  :y ;D
And yes, you can spray some paint into a cap and use it......it generaly works better than touchup as it has more thinners in it.
Tony H
QuoteAs a first go, get some touchup paint (VXs own is usualy best and cheapest) and using the colour and a cocktail stick apply a few layers of colour (leavean hour or so between coats). Then rub any that has spilt over the edges of the scratch with 1200 wet and dry wet (once its fully gone off i.e. a week)).
Repeat with the laquer and finaly cut it to a bright finish........it wont be perfect but will be hard to spot unless you look very closely.
Well worth a try before running into the expense of a professional repair the main thing is to be patient whilst you build up the layers of paint and laquer,to get a good depth  and as Mark says make sure the paint has hardened properly before you attempt to cut it. A drop of washing up liquid in your water help with the cutting process and helps prevent the wet and dry clogging. Good luck  :y
Lawman
Well I should be getting started tomorrow, the paint I have is a good match :y
Going to do the scuff on the bumper aswell. Will take pictures to show my progress 8-)
To be continued!! ;D
Markie
QuoteWell I should be getting started tomorrow, the paint I have is a good match :y
good luck  :y just take your time  :)
nixoro
Sorry to hear of your bad luck barstewards obviously jealous
Hope the repair goes well :y
