Pages: [1] 2 3  All   Go Down
Author Topic: Elite Seats - Drivers not working?  (Read 6488 times)
« on: 01 September 2015, 17:50:20 »
Just tried to put seat in another setting for MrsT, no worky  :(
Passenger seat moves fine, both bottom and back. But drivers seat has nothing, won't slide back or forwards or recline, none of memory options work.  :-\
Almost as if it has no power, blown fuse?  :-\
Re: Elite Seats - Drivers not working?
« Reply #1 on: 01 September 2015, 17:59:35 »
Should add it does not recline either, so not usual something stuck in rails.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #2 on: 01 September 2015, 18:25:22 »
Check one of the plugs hasn't come out under the seat. If they are ok check there is power getting to them.
« Reply #3 on: 01 September 2015, 18:28:55 »
Plugs look fine, as far as I can see. Checked the fuses, all good.
Windows, mirrors etc all work. Just nothing on drivers seat. Rear footwells always kept very clear, so can't see anything trapping or pulling cables.  :-\
Migv6 le Frog Fan
« Reply #4 on: 01 September 2015, 18:33:50 »
I would pull the plugs out and check for voltage to them,and go from there.
« Reply #5 on: 01 September 2015, 18:37:37 »
Need to invest in a volt meter  :(
Migv6 le Frog Fan
« Reply #6 on: 01 September 2015, 18:41:53 »
A 12v bulb with wires attached might suffice.  ;)
« Reply #7 on: 01 September 2015, 18:47:42 »
F5 and F12
F5 being more likely, as F12 affects the entire world and his dog
« Reply #8 on: 01 September 2015, 18:48:54 »
F5 and F12
Checked all fuses under steering wheel, all fine. F5 was first stop. Looks fine  :-\
« Reply #9 on: 01 September 2015, 18:52:07 »
OK, go buy a meter then :)
EMD
  • Noofhampton
    • 95t
« Reply #10 on: 01 September 2015, 18:58:31 »
Electric seats in the 2.5 never worked when i bought it , sprayed the worm screw thing underneath the seat with penetration spray left it then came back a while later and they both worked  :)
Omegatitis
« Reply #11 on: 01 September 2015, 19:05:34 »
Fixed. Loom connector was loose, decided to give them all a wiggle and one just fell out. Popped it back in, with a nice healthy click. It's all working again.  :)
MrsT pleased as she can take 3.2 tomorrow  :)
Migv6 le Frog Fan
« Reply #12 on: 01 September 2015, 19:27:00 »
Told ya.  :P ;D
« Reply #13 on: 01 September 2015, 19:29:34 »
Does she hate your 2.2 as much as everyone else? ;D
Glad its sorted. Generally bombproof, so rare for anything other than fuse or loom fault.
« Reply #14 on: 01 September 2015, 19:42:15 »
She likes the autobox, plus not keen on 2.2's hand brake. Too stiff apparently, but it works fine for me.  :D
Used 3.2 today, I'm starting to get attached to the gas guzzler  ::)
Need to schedule that car work weekend, sort that dead tappet and it might be ready for LPG....... one day  ::)
Pages: [1] 2 3  All   Go Up
