Pages: 1 [2] 3  All   Go Down
Author Topic: Silly question. How do you operate cruise control  (Read 13691 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: Silly question. How do you operate cruise control
« Reply #15 on: 05 September 2015, 21:35:05 »
I fitted it to my 2001 cd cause i had it in my 98 cdx but now i always forget its there and never use it  ;D
conalnugent
  • n. ireland
« Reply #16 on: 17 September 2015, 09:19:56 »
Removed the plastics round the steering wheel there this morning along with another heap of stuff. Anyway this is what I found. All wiring seems all ok and plugged in ect but I know nothing about wiring so have a look and tell me what yous think.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #17 on: 17 September 2015, 10:06:54 »
Looks 'normal'. May be corrected on this, but the [what looks like a] single wire with foam round it is the cruise control one? This based on owning an Omega with non-functioning cruise, and upon inspection, snapped wires here. The rest of the stalk functions worked fine.
Three wire on petrol, two wire on Diseasel, I think.  :)
conalnugent
  • n. ireland
« Reply #18 on: 17 September 2015, 10:16:22 »
Bad angle picture. Need to double check. There's 2 wires there. Maybe 3
conalnugent
  • n. ireland
« Reply #19 on: 17 September 2015, 11:01:37 »
It's got 2 wires for the cruise control. One is white/light grey the other is a light blue.
Any ideas what to check next? I've a multi meter at home but would need talked through what to do
 (Electrics spaz)
« Reply #20 on: 17 September 2015, 11:50:39 »
If it won't switch on and all else seems in order, you need to renew the clutch and brake switches as one of the might be sticking which will prevent the cruise from engaging :y
« Reply #21 on: 17 September 2015, 11:53:02 »
... you need to renew the clutch and brake switches as one of the might be sticking which will prevent the cruise from engaging :y
or at least check its adjustment. I once fitted a new brake switch (wouldn't come out of Park) and lost cruise unless I lifted the brake pedal. Another click on the switch sorted it.  ;)
« Reply #22 on: 17 September 2015, 11:56:18 »
If no good on the above (as it costs nothing to check) my next port of call would be another switch. Depends, I've got a few guys round my way that have odd old Omega bits which I m lucky in that I get charged a pittance, or even given hem for free. There must be someone who has a spare on here. To be honest, even f it turns out not to be the switch, worth having a spare one anyway, as they're on the 'known failures at high mileage' list.
I'll look in my spares boxes, as a TD two-wire one is no use to me, and have no desire to return to Turbo Weasel ownership in the future  :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #23 on: 17 September 2015, 12:32:51 »
My '99 TD CDX has cruise as standard, therefore as Elite, yours must have had a failure if its a new stalk. :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #24 on: 17 September 2015, 13:23:52 »
 (Electrics spaz)
If you've got a TD 2 wire stalk fitted, measure the resistive loop of the stalk first, this tells the ECU a Cruise Stalk is fitted, as without this the Cruise wont work, no matter what button you press.
Disconnect the Stalk and with the Stalk isolated, measure the loop resistance (across the 2 pins) you should see a loop resistance in the region of 670 ohms. Then by pressing each button in turn you should see the following resistive changes -
Normal, Idle, loop resistance = 670 ohms
Press Cruise On / Speed Increase = 67 ohms
Press Speed Decrease / Resume = 167 ohms
Press Speed Reset / Cruise Off = 1.6k ohms.
« Last Edit: 17 September 2015, 13:26:05 by zirk »
conalnugent
  • n. ireland
« Reply #25 on: 17 September 2015, 14:29:18 »
Thanks very much all of you guys. Will try the multi meter and check the adjustment on the switches on pedals.
Daft question agsin as it's an area I've never had to poke at but is the switches on the pedals easy got at of is there a certain degree of stripping needed?
My td estate is in beautiful condition and just want to get these niggles sorted. Have everything working as it should.
Oh yes and get my lsd fitted but that's another story....
zirk
  • Epping Forest
« Reply #26 on: 17 September 2015, 14:38:05 »
Oh yes and get my lsd fitted but that's another Car Park story....
Fixed that for you.  ;D
conalnugent
  • n. ireland
« Reply #27 on: 17 September 2015, 14:52:28 »
First check if the trailing wire from the stalk is 2 or 3 wire (just remove upper cowling)
It's 2 wire. Will check resistance then pedal swithces
conalnugent
  • n. ireland
« Reply #28 on: 17 September 2015, 15:13:17 »
Cheeky bugger. It's the lsd out of my old silver saloon. Never let me down. Will get a wee thread on the go for that when I start stripping and painting ect
conalnugent
  • n. ireland
« Reply #29 on: 18 September 2015, 19:49:14 »
 (Electrics spaz)
Just done this with help from my neighbour. All readings are as you mentioned.
Take it the next port of call is the pedal switches????
Pages: 1 [2] 3  All   Go Up
