Author Topic: Degreasing new discs  (Read 6119 times)
relluf
« on: 11 September 2015, 20:11:22 »
Hi I am fitting new discs and pads to the 2.2 tomorrow, so not sure what is the best option to degrease the new discs, would carb cleaner be ok or should I go buy some brake cleaner?
I am sure there will be an OOF way to do it!
And yes before anyone asks they are a genuine VX disc and pad kit!
Cheers.
Re: Degreasing new discs
« Reply #1 on: 11 September 2015, 20:15:18 »
Ive used Gunk previously  :y
X30XE
  • UK
    • 740i,728i,S320 & Disco
« Reply #2 on: 11 September 2015, 20:36:30 »
White spirit...turps...petrol... diesel... citrus degreaser...
Omegatitis : [in remission]
relluf
« Reply #3 on: 11 September 2015, 20:45:40 »
Ha Ha Ok I get the picture !
 Thanks so just about anything will do ,petrol on a rag?
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 11 September 2015, 21:09:10 »
Most of those are still going to leave some layer of oily finish, which isn't good for brakes!
I like cellulose thinners, but that's because it's cheap and I have it in stock for painting.
Your best bet is to buy a can of brake cleaner when you order the discs. This will allow you to clean the calipers and other mounting surfaces when doing the job, but not have large amounts of agressive solvent left over.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 11 September 2015, 21:20:39 »
I use petrol, leave's a clean grease free surface  :y
Or if i'am feeling flush buy a tin of brake and clutch cleaner.
Hoof'land storeman.
X30XE
  • UK
« Reply #6 on: 11 September 2015, 21:27:00 »
Just don't spill any on your tarmac drive (if you have one). Will go through it like a hot knife through butter.  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #7 on: 11 September 2015, 21:27:05 »
I use this stuff LINK  :y
biggriffin
« Reply #8 on: 11 September 2015, 21:28:54 »
Gallon of petrol cheaper than that. Cellulose thinner's even cheaper, :y
Hoof'land storeman.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #9 on: 11 September 2015, 21:30:38 »
It looks pretty on the shelf though  :D ;D
relluf
« Reply #10 on: 11 September 2015, 21:33:33 »
Right , I have a gallon of petrol and am I right in thinking it evaporates anyway so should not leave any film or residue? Oh and a gravel drive so no tarmac to worry about.
lets hope the rain keeps off.
Thanks for all the input.
biggriffin
« Reply #11 on: 11 September 2015, 21:42:49 »
You are correct, just get a washing up bowl, put disc in, pour small amount of petrol in,then get your paint brush,and brush petrol all over, take out,stand, allow to dry, fit, repeat to other disc  :y
Hoof'land storeman.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #12 on: 11 September 2015, 21:44:30 »
Very important Man Rule. Any car products bought, whether necessary or not, must look impressive when put on a shelf. The more variants of essentially the same product, the better!
EMD
  • Noofhampton
    • 95t
« Reply #13 on: 12 September 2015, 16:01:31 »
Ecp had brake cleaner on offer for mighty big cans  :y
Omegatitis
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #14 on: 12 September 2015, 19:29:45 »
Pop em in the Dishwasher on a hot cycle  :D :D :D :D
Don't tell the Mrs   ;)
