Author Topic: outside temp sensor  (Read 6881 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
outside temp sensor
« on: 15 September 2015, 18:42:19 »
Hi Guys,would the above make any difference to cabin heat.Driving to work this morning heaters on full,when doing 70 on the A19.Farley warm air coming out if the heaters,caught in a traffic jam cool air out of the heaters.Why the difference when moving and stationary,or is this hbv/matrix problem.TIA Dean. :y
Re: outside temp sensor
« Reply #1 on: 15 September 2015, 18:44:32 »
Hi Guys,would the above make any difference to cabin heat. ....
Astra G Facelift yes ....... pre-facelift no  :y
moggy
  • hartlepool
« Reply #2 on: 15 September 2015, 18:49:48 »
Hi Andy 1995 omega,so hbv and matrix flush.Easy to do or a PITA.Dean.
« Reply #3 on: 15 September 2015, 18:56:23 »
HBV isn't hard, just a PITA for access ...... buy a box of plasters  :y http://www.omegaowners.com/forum/index.php?topic=90574.0
I never had need for a matrix flush, so never did one, how about a complete flush of the cooling system  :-\
moggy
  • hartlepool
« Reply #4 on: 15 September 2015, 19:07:27 »
Andy had a full service in feb,oil coolant ect when the mot was being done.Would the hbv cause the symptoms i am seeing.Dean.
« Reply #5 on: 15 September 2015, 20:24:51 »
Could your thermostat be stuck open? What temp does your gauge show? Starting your car from cold, the radiator top hose should stay cold & then as the car gets to temperature it should get warm fairly quickly. If the stat is stuck open, then the top hose will get warm slowly as the engine tries to get to temp.
I forget now which way the vacuum or lack of it on the HBV affects it, but removing the small vacuum hose should make the temp go one way or the other.
moggy
  • hartlepool
« Reply #6 on: 16 September 2015, 17:52:16 »
Hi Andy,temp is bang on 92.New thermostat and water pump fitted 3years ago car gets up to temp,within a mile. :-\
« Reply #7 on: 16 September 2015, 18:47:18 »
It's not your stat then.  :y
What about removing the vacuum pipe from the HBV? Does that make a difference to the cabin temp?
moggy
  • hartlepool
« Reply #8 on: 16 September 2015, 19:16:03 »
Andy just me being a pain,if i remove the vac pipe should the cabin temp go up or down.And what would that tell me,hbv breaked or good.Thanks again mate,Dean.
« Reply #9 on: 16 September 2015, 19:49:07 »
.... Andy just me being a pain,if i remove the vac pipe should the cabin temp go up or down.And what would that tell me,hbv breaked or good.Thanks again mate,Dean.
As above, I can't remember ..... but it can only go hot or cold  ;). The other option is that the valve behind the glove box which switches the vacuum is fubar'd.  :-\
moggy
  • hartlepool
« Reply #10 on: 16 September 2015, 20:47:32 »
Ok Mate,think i will have a look on here,as to what happens with vac pipe removed.Also did not know of said valve behind the glove box,is it accessible.
« Reply #11 on: 16 September 2015, 20:51:35 »
.....Also did not know of said valve behind the glove box, is it accessible.
Sorry, don't know.  :-\
Where's RobG when you need him?  :-\
« Reply #12 on: 16 September 2015, 22:30:00 »
Remove vac pipe from top of HBV and place a small screw in the pipe leaving the HBV open to atmosphere ... system should now run full hot water through the heater matrix as "bypass" is inoperative ... HTH :)
« Reply #13 on: 17 September 2015, 08:20:22 »
Up on the R/H side of glovebox from pass. seat
moggy
  • hartlepool
« Reply #14 on: 17 September 2015, 19:50:27 »
Thanks Entwwod,will try this.Can i just reach in and pull it off. :y
