Author Topic: V6 Nasty Engine Noise  (Read 14852 times)
Rods2
  • Sandhurst Berkshire
    • 1999 3.0 Elite Estate
Re: V6 Nasty Engine Noise
« Reply #45 on: 28 September 2015, 22:01:29 »
My thoughts are either a foreign object or an incorrect cam that has a lot of endfloat, so the cams areas have moved around. The fact you have aluminium broken off both sides of the bearing means it is unlikely to be a casting fault / fatigue that has caused the issue but something hitting it. The gouges on the head look reminiscent of when a Honda 250 I had, sh!t metal choke flap broke up and was ingested by the engine. The piston and to a much lessor extent the head was marked similar to that. If there is no foreign object in the cam box then I would check the oilways and sump as you don't want a blocked oil feed and finding it would confirm the source of the problem.
I think it is unlikely, but where the left and right cam sprockets are different to allow for the offset of the cylinder banks, has there been an issue there?
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #46 on: 29 September 2015, 00:10:40 »
pm sent  :y
« Reply #47 on: 30 September 2015, 10:53:45 »
So do we concur something has broken off as opposed to just the way it was cast?
Thing is... The strainer is clear, as are the t vents. What else is there to check other than actual oil pressure?
I'm guessing bare minimum I need a new head and cams then, possibly 2? :(
  • Auckland
    • Mazda MPV
« Reply #48 on: 30 September 2015, 20:47:40 »
What do the journals on the cams look like?
The head is soft - the cams hard. If the cams are good then I wouldn't be concerned about minor surface marks on the journals,
I would be most concerned about excessive clearance allowing the cams to rattle around and/or lack of oil pressure.
zoomer
  • Finland
    • Omega MV6 Caravan -94
« Reply #49 on: 19 January 2016, 10:56:19 »
Tapping sounds a lot like Connecting rod bearing issue imho ?
Pages: 1 2 3 [4]  All   Go Up
