Author Topic: Wet floor  (Read 8132 times)
Ralph
  • Northumberland
    • 2.6 MV6
Wet floor
« on: 21 September 2015, 20:51:36 »
Water is collecting in the passenger rear footwell, blocked vent I assumed.
No there is nothing in the heater air intake, the vent plug at the bottom is missing & the resulting hole is clear.
The pollen filter is dry.
The water appears to be coming from the heater vent under the seat as it is wet.
The car isn't loosing coolant & the water i've got out of the carpet is relatively clean.
Where else can it get in to the vent system?
Re: Wet floor
« Reply #1 on: 21 September 2015, 20:55:36 »
Door seals :-\
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Wet floor
« Reply #2 on: 21 September 2015, 21:24:38 »
Has the car been parked on an incline of any significance since you noticed this happening?  Might give a better indication as to where the water is coming from?  :-\
Ralph
  • Northumberland
    • 2.6 MV6
Re: Wet floor
« Reply #3 on: 22 September 2015, 11:56:04 »
No the car hasn't been parked on a hill or anything other than level ground.
Ralph
  • Northumberland
    • 2.6 MV6
Re: Wet floor
« Reply #4 on: 22 September 2015, 11:59:17 »
Door seals :-\
The n/s rear door was replaced 14 months ago but the water ingress has only just manifested itself in the last two weeks.
I'll have to get someone to put a hose on it while I sit inside, the carpet does seem to be wetter in the heater duct area.
Re: Wet floor
« Reply #5 on: 22 September 2015, 12:19:46 »
Look underneath the car, on the 2.2 I had a very odd hole underneath. I think from a drain plug used at build maybe? But it was missing, meaning water from outside could come inside the car.
I sealed it with some araldite some years ago
Re: Wet floor
« Reply #6 on: 22 September 2015, 13:55:16 »
That's a paint drain :y Sealing with a rubber plug was/is the most effective way of sealing it without damaging the paint, which in turn prevents rusting of the hole :y
Re: Wet floor
« Reply #7 on: 22 September 2015, 15:30:21 »
Always wondered what happend to it, no damage or marks suggesting it was ripped off.  :-\
Guessing they forgot to put it in!
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Wet floor
« Reply #8 on: 22 September 2015, 16:40:56 »
maybe it's just an over-excited passenger? ::)
Ralph
  • Northumberland
    • 2.6 MV6
Re: Wet floor
« Reply #9 on: 24 September 2015, 13:41:59 »
We've just had a shower of fairly heavy rain, on first inspection nothing had got in to the car.
After less than a mile home there is a clear trail of water emanating from the LH side of the heater duct under the passenger seat.
As the intake is clear with no rubber valve at the bottom how on earth can it get into the heater ducts?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Wet floor
« Reply #10 on: 24 September 2015, 14:43:23 »
My thoughts would a leak or something amiss around the scuttle / pollen filter area  :-\
Re: Wet floor
« Reply #11 on: 24 September 2015, 15:29:31 »
.. in a Desmond? :-X
Ralph
  • Northumberland
    • 2.6 MV6
Re: Wet floor
« Reply #12 on: 24 September 2015, 18:37:20 »
.. in a Desmond? :-
A desmond ?http://images.omegaowners.com/forum/smf2000/Smileys/oofstd/huh.gif
Re: Wet floor
« Reply #13 on: 24 September 2015, 19:41:02 »
2.2= Desmond=Tutu ::)
2nddaniel
  • Heywood
  • I swerve for HGV's.
    • Omega 3.0 V6 Elite
    • Cheesey peas
Re: Wet floor
« Reply #14 on: 24 September 2015, 20:52:43 »
Might be worth checking your sunroof drains (if you have one).
I have the same problem, water passenger footwell, and not blocked scuttle drain, but I discovered recently that the sunroof doesn't always close tight at the front edge, so I only occasionally find a leak.
I should really get around to investigating it.
Weapons officer, prepare to fire.
I am prepared. I'm the weapons officer.
