Author Topic: Wheel Tire Combination and Alignment  (Read 2897 times)
cyberfarmer
« on: 25 September 2015, 05:56:26 »
September 25, 2015
Hi to all,
What is the best fit and size for a tire-wheels combination for a V6?
for 17s
for 18s
and any adjustments on toe and camber if stock wheels are changed?
**considering that the suspension is stock
Thanks in advance
Re: Wheel Tire Combination and Alignment
« Reply #1 on: 25 September 2015, 11:32:33 »
Assuming Omega 7J 17" ET33 wheels, then you have but one choice... 235/45/17s
Assuming Irmscher 8J 18"s ET30/33, then you have two legitimate choices... 235/40/18s or 245/40/18s (these are the same rolling radius as factory 16"s running 225/55/16 tyres, so speedo remains consistent).
If you're fitting Irmscher 9J 18"s at the rear then it's 265/35/18s :y
cyberfarmer
« Reply #2 on: 26 September 2015, 01:51:10 »
Super thank you sir!
Spireite
« Reply #3 on: 26 September 2015, 10:35:22 »
I think you'll find the standard 17 inch rim width is 7.5j.
I run 245/45/17 which is a near identical comprison to 225/55/16, with a tweek to the electronic speedo and abs pulse.  Thats the case for the preface and miniface anyway, whereby the elite had 16's.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 26 September 2015, 10:35:28 »
Cor a tyre and geometry thread, this could go on longer than webbys 0-60 thread.
Right
 I think auto-grip winter tyres are doggie dangling bits ;D
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 26 September 2015, 11:33:40 »
It won't while Gixer is banned.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #6 on: 26 September 2015, 11:46:26 »
 ;D ;D
To be fair to Vagisil Chris, when it comes down to tyres and suspension, he has helped a lot of lads out on here and has probably forgotten more about this stuff then most members know :)
Even if he is a irritating t@at sometimes  :D :D :D
biggriffin
« Reply #7 on: 26 September 2015, 13:48:06 »
It will if we say my tyres are better than yours,  ;D
Hoof'land storeman.
« Reply #8 on: 26 September 2015, 13:58:33 »
Oh no they're not...
biggriffin
« Reply #9 on: 26 September 2015, 19:33:33 »
Mine are round. :D
Hoof'land storeman.
biggriffin
« Reply #10 on: 26 September 2015, 19:34:13 »
Come on young bear :o
Hoof'land storeman.
