Author Topic: Down on Power  (Read 1778 times)
Down on Power
« on: 26 September 2015, 17:33:01 »
I've had a bit of a blow coming from the SAI pump (I think) which has been disconnected for years but left in place and I realised the other day when I tried the 0 - 60 that it was a bit sluggish which I put down to the escape of exhaust gases.  :-\
Yesterday however the blow became very noisey and when I was flooring it all I was getting was a lot of noise and what power was there was jerky.  ::)
On investigation I've found 3 things.
1) SAI pipe has popped off of the manifold pipe on the offside.
2) One of the vac pipes from the front vac box has melted through where it was touching the stainless SAI pipe (the one that goes across the front of the engine).
3) The cable from the nearside bank of LPG injectors has melted through to the wires where it was touching the stainless SAI pipe.
So all in all whilst it's a PITA, it's nothing serious and fixable. :y  It's a bit strange though that the stainless pipe has got hot enough to melt things and the rubber pipe has popped off!  :-\  I havn't done any work in that region for ages, so it's not like the vac pipe and wiring has been disturbed recently.  ::)  :(
I'm undecided whether to strip out all the SAI stuff and blank off the pipes at the manifolds or get another pump and reinstate the system.  :-\
tidla
  • solihull
Re: Down on Power
« Reply #1 on: 26 September 2015, 20:53:01 »
might be a blocked cat..
Re: Down on Power
« Reply #2 on: 26 September 2015, 22:59:30 »
Hope not.  :(
A spot of googling suggests that the one way valve is kaput, so I'll blank off the pipes at the manifolds and see how she goes.  :-\
Re: Down on Power
« Reply #3 on: 27 September 2015, 00:00:36 »
Hope not.  :(
Yep. Sounds like a good plan. :y
Re: Down on Power
« Reply #4 on: 27 September 2015, 16:44:32 »
If I strip out the stainless SAI pipe that runs across the front of the engine and blank off the two pipes from the manifolds.  What do I do with the plastic valve that is plumbed in as well?  It has a vac pipe and an electrical connector as well as the rubber pipe.
This one.
I'm thinking of leaving it in place and blanking off the right hand pipe.  :-\  Good plan?  ???  TIA!  :y
Re: Down on Power
« Reply #5 on: 27 September 2015, 17:04:05 »
Or can I strip out the whole SAI system, pump, pipework the lot?  Will it throw any codes? EML light on?  :-\
