Author Topic: X30xe few errors  (Read 3299 times)
calibrated
  • Croatia
    • Opel Calibra
X30xe few errors
« on: 01 October 2015, 14:58:42 »
As you know i transplanted x30xe to calibra..i menaged to bypass the immobiliser..however when i start engine(cold) i got EML staying on after 15 seconds of car working...i get following codes in this particular order when doing paper clip test
12 - initiation of diagnosis
135 - tail light,this is not connected in calibra so its normal to be registered
46 - secondary air injection pump,also not connected in calibra..i welded holes on exhaust manifolds
17 -knock sensor circuit 2
129 - egr voltage low
63- inlet manifold valve 1 voltage high
73 - maf sensor voltage low
Car is running like shit,stuttering in neutral and when driving,giving a puff of black smoke when hitting throttle...other than that there is no blue or white smoke at least....
GmasterT
  • Cambridge
  • does that drifting thing...
Re: X30xe few errors
« Reply #1 on: 08 October 2015, 15:35:32 »
Even though you have welded up egr nonsense, have you left it plugged in?
calibrated
  • Croatia
    • Opel Calibra
« Reply #2 on: 09 October 2015, 16:17:12 »
I didnt weld it.. I left it as original,connected to exhaust..however i didnt connect VSS signal to ecu..can it affect engine idling and performance? Cause i have symptoms of bad maf and bad coilpack,and i have read that ecu can cause this because off not getting the VSS signal..maf and coilpack are tested and working good..
GmasterT
  • Cambridge
« Reply #3 on: 12 October 2015, 01:23:41 »
As in the crank sensor?
calibrated
  • Croatia
    • Opel Calibra
« Reply #4 on: 12 October 2015, 16:58:30 »
If we speak about signal VSS its from speedo to ecu..however i connected it and no joy...blocked egr,no joy either...ill try new leads and sparks...engine is idling on 5 cylinders sometimes going on 4...coilpack tested,condition good...
« Reply #5 on: 12 October 2015, 17:37:30 »
You have an air leak.....the MAF code is the key.
Hence running like a dog.
Its worth checking the wiring to the bank 2 knock sensor to ensure its ok.
The secondary air injection codes and front multiram code can be tricked with a 1k ohm resistor
