Author Topic: Which sealant for the sump pan?  (Read 2556 times)
« on: 03 October 2015, 19:25:42 »
As above...
Black or grey goo :-\
Re: Which sealant for the sump pan?
« Reply #1 on: 03 October 2015, 19:29:21 »
I used grey, but it had black on it when I took it off.  ::)
I did buy a tube of other automotive sealant which was red and much cheaper than Vx goo, but as I had some grey left I used that.  :y
It's doing the job.  8)
« Reply #2 on: 03 October 2015, 19:35:05 »
 :y need to stock up ready... black one is a bit, um, leaky ::)
« Reply #3 on: 03 October 2015, 19:45:33 »
As above...
grey  :y :y ..... it sets fairly hard
the black stuff stays rubbery even when set and I'd guess the stuff that squeezed out in the inside would eventually come off due to the hot oil ....... like it did on her/our/my Smart
« Reply #4 on: 03 October 2015, 19:48:42 »
That makes sense... there's evidence of it having been done before
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #5 on: 03 October 2015, 19:53:04 »
I always go, metal to metal Grey, metal to gasket Black.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 03 October 2015, 21:30:17 »
Loctite 5910 flange sealant.
Black, semi setting RTV intended for permanent oil contact. Like sumps. Probably the OE supplier anyway.
« Reply #7 on: 03 October 2015, 21:41:59 »
so Loctite black is the same as GM's grey?  ::) ::)
  • Chatham, Kent
« Reply #8 on: 03 October 2015, 21:52:35 »
It doesn't actually matter as ordinary household silicone, in whatever colour you have lying about, will do the job. The important thing is that you only need a smear of whatever you use in the join to work properly.
Several years ago I was told by an Ilmor engine builder that the head gaskets were the only 2 gaskets in the engine. Everything else was sealed with Dow Corning 797 clear silicone  as used by the pallet load by window fitters.
« Reply #9 on: 03 October 2015, 21:59:11 »
A smear of A N Other sealant might very well be OK on things where there is a proper metal to metal contact over a reasonable area, a sump is a presses steel affair & the mating surface is unlikely to seal with just a smear
« Last Edit: 03 October 2015, 22:01:23 by Andy B »
