Pages: [1] 2 3  All   Go Down
Author Topic: whats that " beeping"  (Read 10837 times)
vauxsull
  • Garden City, North Wales
    • 3.0 Elite
« on: 07 October 2015, 04:38:01 »
I hear when I take my key out? 4 or 5 beeps in quick succession before I've even got out the car and locked it.. Impossible to describe the pitch of the noise in words but sounds like a bird chirping I spose....
Re: whats that " beeping"
« Reply #1 on: 07 October 2015, 06:13:02 »
Power sounder batteries on their last legs. Remove it. Sooner than later... :y
vauxsull
    • 3.0 Elite
« Reply #2 on: 07 October 2015, 07:33:12 »
So more than just pulling a fuse out then? Where does it live and what's the method of disconnecting it?
vauxsull
    • 3.0 Elite
« Reply #4 on: 07 October 2015, 07:53:56 »
Sod it... I took the scuttle off the other week to reseal it to save new dis pack getting wet.. Looking at the " how to" why ( after disconnecting power sounder) would I need to refit it? Cant I sling it in the bin?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 07 October 2015, 07:58:10 »
Very well documented on here.
Remove and dispose of, before,it bursts into flames.
Hoof'land storeman.
powerslinky
« Reply #6 on: 07 October 2015, 08:15:56 »
Sod it... I took thescuttle o ff the other week to reseal it to save new dis pack getting wet.. Looking at the " how to" why ( after disconnecting power sounder) would I need to refit it? Cant I sling it in the bin?
You can disconnect & remove the PS  without completly removing the scuttle. I  did one on the silver 3.2 last week .
I removed drivers side wiper arm , the one torx screw on drivers side & the first 2 or 3 scuttle clips on that  side.
Scuttle will then lift enough to be able to get to the 10mm nut that holds the PS in place. Just undo it a few turns & the it
will lift off upwards & out. ( I did not try to  fit a replacement  PS with  this method though as only removed mine)
 Disconnect electrical connector & wrap with insulation tape if you are not fitting a new one .
As for the old PS  . . . Don't just bin it  . . . see maintenance guide as to why  ;) ;)  HTH
If you go to the Wycombe meet on Saturday  . . . no doubt someone will remove it for you  . .  even if it's me   ;D ;D
EDIT: Ah   . .  just noticed  . . . unlikely you will  be going to Wycombe as you live in North Wales ::) ::)
« Last Edit: 07 October 2015, 08:18:24 by Essex Big Al »
vauxsull
    • 3.0 Elite
« Reply #7 on: 07 October 2015, 08:29:21 »
This is coming out on Saturday then..  Don't want my Miggy turning into toast.
biggriffin
« Reply #8 on: 07 October 2015, 08:31:21 »
Do it today Saturday could be to late.
Takes 5mins. :y
Hoof'land storeman.
vauxsull
    • 3.0 Elite
« Reply #9 on: 07 October 2015, 08:35:09 »
Worried me now... :-X
vauxsull
    • 3.0 Elite
« Reply #10 on: 07 October 2015, 08:38:40 »
That's it... coming out during my dinner break today if it don't rain..
vauxsull
    • 3.0 Elite
« Reply #11 on: 07 October 2015, 08:51:25 »
Looked in maintenance guides and can't see why I can't just bin it when its out?...
pauls
  • By the sea minehead
    • Bmw x3
« Reply #12 on: 07 October 2015, 09:02:28 »
When I did mine I took it out put it in a bucket of water until it stopped churping I then put it in the bin. :y
vauxsull
    • 3.0 Elite
« Reply #13 on: 07 October 2015, 09:06:33 »
So you drowned it then? 😆
ted_one
« Reply #14 on: 07 October 2015, 09:18:34 »
Taxi Al did mine....he took it to a quiet spot and executed it with a very large club hammer ....very nasty!! :o  ;D
Pages: [1] 2 3  All   Go Up
