Author Topic: Another parking sensor question  (Read 3062 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« on: 09 October 2015, 17:32:51 »
Hi all...
One of my parking sensors has gone inside the bumper. Before I go mucking something up, can I get to it by taking off that plastic bit just inside the boot, or is there metal behind it. I noticed in the two 'How to's' that those sensors are fitted in the lower part of the bumper, but mine are fitted in the top part, above that crease that goes all around. I could not initially see a way through from underneath, but that might be my eyes. I hope the bumper does not have to come off :(
I am talking 2003 CD Saloon.
Reason for not going in blind...swmbo has demanded I go here first, before I cock something up >:(
Thanks in advance :y
« Last Edit: 09 October 2015, 17:35:58 by terbert »
Re: Another parking sensor question
« Reply #1 on: 09 October 2015, 17:34:57 »
May well have to remove bumper
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #2 on: 09 October 2015, 18:05:51 »
Ooooh...that's a bummer. I can see it just lurking inside the hole. Can't see how to pull it through.
Definitely no access from under.
Probably in fantasy land now...but if there is a metal panel behind the plastic..what if I cut an access hole big enough to get some tool in, behind the sensor, it would not be visable, and surely if would not affect safety. I think taking off bumpers would be a bit above me, mate :(
pauls
  • By the sea minehead
    • Bmw x3
« Reply #3 on: 09 October 2015, 18:07:54 »
We can have it off tomorrow if you can wait. you taking a trolley jack
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #4 on: 09 October 2015, 18:11:12 »
Are you serious, Paul, I mean about getting it off...I shall have two trolley jacks there :o
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
« Reply #5 on: 09 October 2015, 18:28:09 »
If it's a facelift model you don't need a trolley jack to remove the rear bumper. It is 4 screws along the top under little plastic caps. One at the top in each wheel arch and one underneath behind each wheel. There are 2 plastic clips underneath below the number plate that have a pin you need to push through.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #6 on: 09 October 2015, 18:39:40 »
Yes..its facelift. Just had a look, at the thing, all looks like on the ground job. Are the four plastic bits on top, those shaped like an oval (race track) and need to be prised out. :y
Paul...I reckon tomorrow is a goer ;D :y
pauls
    • Bmw x3
« Reply #7 on: 09 October 2015, 19:10:47 »
We can do while on the ground. when i replaced mine it was quicker to do it from underneath. Also no chance of busting the screw mounts in the wheel arch.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #8 on: 09 October 2015, 19:18:20 »
Whichever way you want, Paul. I am in your hands, and grateful :y
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
« Reply #9 on: 09 October 2015, 19:40:31 »
The little oval covers do need to be carefully prised out. They have a little clip at each end so try to do it from the curved end rather then the long edge to reduce the chance of snapping the clips.
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #10 on: 09 October 2015, 19:44:43 »
Thankyou :y
I expect Paul knows the gen, but, if something happens that he does not make the meet, then I am forewarned :y
Oh...I have read the maintenance section, but I couldn't see the plastic clip things. So leave to someone who knows :y
« Last Edit: 09 October 2015, 19:55:30 by terbert »
Merlindriver
  • Shropshire
  • Omega 3.2 Elite
« Reply #11 on: 09 October 2015, 20:00:11 »
They are on the bottom lip of the bumper, one is quite close to the exhaust cut-out. About the size of a 1 pence.
