Pages: 1 2 [3]  All   Go Down
Author Topic: Better brakes....?  (Read 11742 times)
Vega
  • The Netherlands
    • Omega Saloon 3.2
Re: Better brakes....?
« Reply #30 on: 26 October 2015, 00:27:45 »
Monaro calipers are on the cards, one day for sure, but anything up on that and I suspect the original 15"s and consequently the spare wheel won't fit over them:)
The GTO/Monaro calipers will clear the standard 16 inch Catera wheels. Can't verify whether they'll fit with the spare. Never thought about it. I'm screwed if it doesn't and I get a flat up front.
The 15" steel rim spare will fit the setup with the GTO calipers.
http://www.opelomegaportal.nl/viewtopic.php?f=24&t=37 (Sorry its in Dutch).
I am working on the next brake setup with larger rotors 345mm .
« Reply #31 on: 26 October 2015, 10:59:40 »
Only if you use the 2004 calipers with the standard discs... Monaro VXR standard discs are 330x32 fronts and 314x18 rears and the caliper brackets are spaced differently to allow for this. Believe this is the 'Corvette' upgrade in the States :-\
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #32 on: 26 October 2015, 13:32:22 »
Monaro '04 Calipers with standard Omega wheels only, then. Anything 'up' on that and we need to start carrying a different spare wheel, then. Fair enough. I can live with that. When I do it, probably some time in summer 2019  :y
« Reply #33 on: 26 October 2015, 13:36:41 »
The VXR sized discs demand 17"+ wheels, the full fat AP etc ones demand a minimum of 18"s :y
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #34 on: 26 October 2015, 14:25:15 »
y
Out of interest, will a FL CD 16" fit in the spare wheel well? I have a surplus and if one fits I'll carry one in the Special when its back on the road...
« Reply #35 on: 26 October 2015, 14:36:29 »
I think technically it doesn't. However, if you jam it in, it will. Might have to have the spare wheel cover on a bit loose or something, if memory serves.
« Reply #36 on: 26 October 2015, 14:39:56 »
y
Be a squeeze, but you should get most of it in... Original spare is a 195 width iirc, the extra 30mm is what tightens it up :y
Pages: 1 2 [3]  All   Go Up
