New addition to the Jv6cdx Fleet
Started by JamesV6CDX, 11 October 2015, 18:15:52
henryd
Looks very nice James,I've always had a soft spot for the E39,much easier on the eye than the E60/61 :y :y
other rides
Quote from: henryd on 11 October 2015, 22:15:23
As are anal warts. ;D
I like the E60, I see it as an advancement on the Omega design in a lot of ways, anything newer than an E60 is yuck though!
Diamond Black Geezer
I'll admit the interior does have a 'feel' that the Omega just doesn't. All the shut lines just seem to be tighter, and as you say, no rattles or squeaks. Looks a good buy. And you can still follow the ATF change guide!  :)
Quote from: Diamond Black Geezer on 12 October 2015, 12:02:30
This one has a drain plug :D
Witchcraft!
So if I see one in a scrappy, I could get me a replacement sump, and convert my box into a drainy-plug type? Nice!
Quote from: Diamond Black Geezer on 12 October 2015, 17:29:02
Witchcraft!
Noooooo
The omega uses the twin sump setup and is the 4L30 4 speed gearbox.
The 5 series is also a Gm box but is the 5 speed 5L40-E setup, with one big sump (and a drain plug!!)
How hard would it be to drill a hole and fit a sump plug? No worse than moving a lambda sensor, surely?
Quote from: STEMO on 12 October 2015, 19:06:01
Not hard at all. If I ever have to remove the sump on mine, I'll be doing just that.
The dipstick/filler tube that it should also have had from the beginning is a bit harder to add.
Quote from: JamesV6CDX on 12 October 2015, 18:41:44
Witchcraft!
Noooooo
Ahh, fair enough.  :y
Will stick with my current setup, then. Just did the ATF last week, so I think we're good for another 180,500 miles  :)
GastronomicKleptomaniac
Just fit the whole box. Job jobbed.
(might need the watchmakers hammer)...
tigers_gonads
The E39 was the best 5 series ever made imo
In fact, I was looking for one to replace my old Omega 2.5 td estate when it turned to rust but couldn't find a decent one in my price range  :(
The thought of driving a E39 M5 still make the old pecker twitch  ;D
Rear wheel drive, 400 brake and a proper gearbox   :y:D :D
Shame they never did a estate version  :'(
