Pages: 1 2 [3]  All   Go Down
Author Topic: Any ideas?  (Read 10578 times)
hoj
  • BURY
Re: Any ideas?
« Reply #30 on: 13 November 2015, 18:54:18 »
At last all done and dusted
Stops straight drives straight
Now to see the guys that did the tracking and bollock them
3.2 Elite in Oyster
Re: Any ideas?
« Reply #31 on: 13 November 2015, 19:00:32 »
Who sorted it for you?
I guess you're going back to Kay Street to hand the bollocking out  ::)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
Re: Any ideas?
« Reply #32 on: 13 November 2015, 19:13:56 »
How much to put it right.Dean.
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Any ideas?
« Reply #33 on: 13 November 2015, 22:41:04 »
I bought another 2.6 Elite in August; according to its history Vauxhall fitted a new steering idler earlier this year and did a 4 wheel on it. The steering wheel was atrocious - the spokes were about 11 / 5 o'clock and it pulled slightly to the n/s. Assuming it hadn't been played with since, doesn't say much for the VX garage who did it...👎 The n/s front tyre was excessively worn on the inside. I had a fresh 4 wheel done (not by VX); the rear toe on the n/s was out, which was adjusted after heat to free off the track control arm and the front toe was out (toeing out). The camber was ok. Dispite this, the steering wheel was still slightly out (10 /4 o'clock) and it still pulled to the left. Not happy, I went back and stayed whilst it was done again - I even asked to check the position of the steering wheel after it had been clamped. I watched whilst every adjustment was made, all now in the green, and I was even invited to do the final rotation of the steering wheel to ensure the arrows on the computer screen moved exactly to the right position. I can only presume a lot more care was taken after I complained and possibly because I stressed I wanted it 100%. It now drives nice and straight, no pulling, and the steering wheel is perfect👍. The equipment used was Hawk Eye. Just shows how important the correct alignment is on the Omega, and having someone who is prepared to put the effort in and more importantly knows how to use the equipment.....
« Last Edit: 13 November 2015, 22:44:44 by johnnydog »
Re: Any ideas?
« Reply #34 on: 14 November 2015, 03:24:38 »
Amen to that :y
You can drive a bus through the green settings :o
johnnydog
  • Lancashire
Re: Any ideas?
« Reply #35 on: 14 November 2015, 09:43:19 »
Maybe so, but the difference between green and red obviously made a big difference to how my Omega drives and steers. It didn't take much to move the settings from red to green, but the difference in the position of the steering wheel and eliminating the pulling was a lot.
Re: Any ideas?
« Reply #36 on: 14 November 2015, 14:53:13 »
Just how horrible or pleasurable the Omega is to drive is down to a gnats hair on the machine... Get it right however, and people are dumbfounded at the difference...
Enjoy your new found driving bliss :y
johnnydog
  • Lancashire
Re: Any ideas?
« Reply #37 on: 14 November 2015, 17:39:26 »
I know I have too many Omegas (or so my 'better' half keeps reminding me), and I have just sold one 3.2 Elite as well......but I had to get this 2.6 Elite, because of its lovely condition, superb service history and it was cheap! Also, it was black, which I think suits the Omega and you don't see that many in that colour.....
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
Re: Any ideas?
« Reply #38 on: 14 November 2015, 19:06:20 »
Worn wishbone bushes or a worn steering idler arm can both cause symptoms as described.
The idler arm is easy to check but the wishbone bushes are hidden away inside the subframe and it is quite common for them to be completely shot.
Huh? they must have moved 'em when they built mine. :-\ :y
Shackeng
  • Ramsbury
Re: Any ideas?
« Reply #39 on: 14 November 2015, 19:10:01 »
Which, as you will know, is the GT colour. :y
Diamond Black Geezer
    • & a silly coupe coming...
Re: Any ideas?
« Reply #40 on: 16 November 2015, 09:07:19 »
The best colour  :)
OP, well chuffed you're sorted, that's the most costly job now sorted. (costly in that, it can cost you four new tyres every 6 months)
Pages: 1 2 [3]  All   Go Up
