Author Topic: Keyfob battery holder  (Read 4096 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« on: 17 October 2015, 19:10:11 »
Hi guys, I got my omega with non working keyfob so I replaced all three press switches and "fixed" broken battery holder with a piece of wire - well you now it couldn't last long  :-X Has anyone here replaced battery holder ? Does anyone know part number?
Because more I search for some compatible part less I get.  I hope you can help me with this one. Thanks in advance, Stan
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
Re: Keyfob battery holder
« Reply #1 on: 18 October 2015, 15:18:14 »
Martin Imber! he,s your man regarding fobs. :y
« Reply #2 on: 19 October 2015, 18:00:46 »
I never found a supplier, but repair is trivial if you can use a soldering iron - just extend the (now broken) battery holder legs with a bit of stiff wire (I use resistor offcuts), and solder in place.
I've probably done about 50 for OOFers, friends and family, and not had any issues with this method.
« Reply #3 on: 20 October 2015, 12:59:30 »
Its also advisable to add some dabs of cyanoacrylate to the battery housing to bond it to the PCB which removes some of the strain on the soldered connectors.
« Reply #4 on: 20 October 2015, 18:39:22 »
Need careful placement, as there are components under the battery holder. I did use a glue gun on the edge of a couple of pesky ones, but would rather not.
danzigfan
« Reply #5 on: 22 October 2015, 18:09:11 »
I replaced micro switches and repaired battery holder as TB has suggested . Everything works fine for now, only thing that bothers me is short distance keyfob works on - 3m away from the car...but it's much better than before :y
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #6 on: 22 October 2015, 18:14:19 »
Silly idea...but it works....
Go a bit further away from your car, put the key blade against your head...and unlock/lock it :y
danzigfan
« Reply #7 on: 22 October 2015, 18:15:32 »
I believe that myth was busted.... :P ;D
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #8 on: 22 October 2015, 19:53:00 »
Well, all I can say is it works with mine.....grandchildren do it and think its 'scary' ;D ;D
    • 530D M Sport, 330i Coupe
« Reply #9 on: 23 October 2015, 23:18:47 »
If you stick the key in your ear and turn it does the car start?
« Reply #10 on: 24 October 2015, 10:24:40 »
It really does work (assuming its the right frequency (and not IR ;D)) as you bonce acts as a resonator.
IME, range probably doubles from about 2m from car to about 4m when I use my chin
