Author Topic: Discs  (Read 1630 times)
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Discs
« on: 20 October 2015, 20:02:49 »
Are the front discs for a F/L Elite the same as for a Senator 3.0 CD?Or are the Omega ones larger/different?Reason for question is I have a pair of brand new boxed Senator ones and I want to know whether to keep them or get rid.
Re: Discs
« Reply #1 on: 20 October 2015, 20:08:39 »
Should be 296x 28mm with an overall disc height of 58.2 ish mm :y
LC0112G
  • Online Online
Re: Discs
« Reply #2 on: 21 October 2015, 09:20:05 »
According to EPC P/n 90392559 is fitted to all Straight 6 Senators and Carltons, plus V6 Omega B's. However, my EPC doesn't cover the 3.2/2.6 Omega B's, so it's possible these are different.
Re: Discs
« Reply #3 on: 21 October 2015, 09:57:12 »
All the same size except for early 8v 2.0s which were 286x24 :y
Keith ABS
  • Maldon Essex
Re: Discs
« Reply #4 on: 21 October 2015, 11:14:43 »
  Some early 2.5 V6 cars and 2.5 diesels were also fitted with the 280mm discs. As long as they are 296mm Baja, they will fit ok
Keith ABS
Re: Discs
« Reply #5 on: 21 October 2015, 17:28:55 »
Definatively, all Omega-B fronts are 296mm, except pre 1998 2.0l, which are 286mm
BazaJT
Re: Discs
« Reply #6 on: 21 October 2015, 18:35:41 »
Sounds good then I'll keep them "in stock",Also have a pair of brand new boxed solid rears for p/f/l so if they're the same[must have a look when I get car back tomorrow to see if mine are solid or vented] I'll be quids in come brake swap time :y
