Author Topic: V6 auxiliary belt diagram - 1997 2.5  (Read 2854 times)
Ian1
  • Weston-super-Mare
    • Omega 2.5 Tourer
« on: 24 October 2015, 09:16:38 »
Hi,
I have tried searching but am unable to find a picture showing the "path" for the auxiliary belt on my Omega. Does anyone have one please as my belt has broken so I have no original to refer to.
Thank you,
Ian
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Re: V6 auxiliary belt diagram - 1997 2.5
« Reply #1 on: 24 October 2015, 10:13:13 »
Assuming you have air-con, it will the one in the bottom left.
sjc
  • Alloa, Scotland
« Reply #2 on: 24 October 2015, 10:15:54 »
And the way you do it is to fit the belt to all the pulleys except the tensioner, then using a socket on the tensioner pullet nut, turn it clock-wise to swivel the tensioner towards the centre of the engine until you can slip the belt onto the tensioner pulley.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 24 October 2015, 11:01:01 »
It is much easier to fit the belt around all of the ribbed pulleys, pull on the tensioner and slip the back of the belt over the smooth water pump pulley.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 24 October 2015, 11:42:48 »
Add watch your fingers when putting the belt over the tensioner making sure you've got a good spanner / wrench grip on the tensioner nut.
  • Auckland
    • Mazda MPV
« Reply #5 on: 24 October 2015, 11:48:14 »
So:
T = tensioner
GEN = generator/alternator
WP = water pump
CS = crank shaft
AC = air conditioning
PAS = power assisted steering
so what is "G" ? :-\ (and what car had it fitted?)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #6 on: 24 October 2015, 12:33:21 »
So:
T = tensioner
WP = water pump
CS = crank shaft
'G' is/was a Guide / Idler Pulley I believe.  :y Not seen one personally though.
Agreed.  :y
« Last Edit: 24 October 2015, 12:35:08 by YZ250 »
