Author Topic: 2-3 solenoid roll pin  (Read 2096 times)
steve6367
« on: 25 October 2015, 12:09:20 »
So I have the box aprart but can't get the security pin out.
Should it just pull out?
Help!
Thanks
Steve
steve6367
Re: 2-3 solenoid roll pin
« Reply #1 on: 25 October 2015, 15:45:01 »
Ok, so took the valve body off and tapped the pin out that way. This raised a question as 2 small ball bearings seem lose - does anyone know if they should be lose at all and if so are the in the correct place in the photo.
Also is this my trust washer in the this pic? If so is it now box out time anyway?
Not having a good day!
Many thanks
Steve
steve6367
« Reply #2 on: 25 October 2015, 21:33:12 »
No thoughts from the experts?  :-[
« Reply #3 on: 26 October 2015, 12:33:22 »
The balls will be from specific locations in the valve block. I think they form non return valves. You'll need a service manual for the box to find out where they should go.
But.. that does look like a broken thrust washer, so the gearbox needs to come out to fix that, or it will soon be coming out for replacement, I'm afraid.
