Author Topic: scanner v pedal trick  (Read 2240 times)
omega2018
    • MercCL500 Omega2.6ManElit
« on: 28 October 2015, 01:04:12 »
an obd-ii scan of my car showed no stored codes but the pedal trick showed one- 0335 'CrankshaftPosition sensor "A" circuit malfunction' ( which is expected - i have just had to replace the crank sensor)
is this a fault with my scanner or does it happen often?  otherwise the scanner seems to be reading the data ok - revs, voltage, engine id etc etc...
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: scanner v pedal trick
« Reply #1 on: 28 October 2015, 08:16:49 »
Ive had that before,, no related codes on the reader but crank sensor on the pedal trick, also had faulty crank and no codes anywhere.
omega2018
« Reply #2 on: 28 October 2015, 12:50:38 »
thanks is that with a cheap bluetooth chinese obd-ii,  like mine,  or a pucker one?   i wonder if it is just my scanner.
zirk
  • Epping Forest
« Reply #3 on: 28 October 2015, 17:00:53 »
It was a 80 quid handheld one although that went walkabout when I left it in a potential sellers car and didn't realises until The train trip home.  >:( so I'm on the cheapo +£20 BT one at the moment, the cheapo cheap under 10 quid BT ones are too problematic.
omega2018
« Reply #4 on: 31 October 2015, 19:43:27 »
mine wouldn't read the crank sensor code but it did clear it for me - odd.
also today it read 11 errors codes on a BMW but would only clear 5,  on one ecu.
